Titan Tank Installation - VIDEO - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 05-05-2011, 10:39 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is online now
EpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud of
Quote:
Originally Posted by lexustbs View Post
Ya, its a nice thump when the tank is around 3/4 full. I just wonder what the fuel does to the sender in the tank? Does yours do this Epic? I would of paid a few hundred extra for the baffles. But with the straps that come with the tank, I dont think its going to come loose. Just place that order Marauder!
I have to be honest, I've never heard or felt the sloshing. I rolled up my windows last November and only rolled them down again in the last couple of days when driving around. It's been a long, cold spring. I'll try to pay attention and see if I can pick it up. I'm thinking those big, heavy straps though are WAY over engineered for just this reason. I seriously doubt that there's any real concern for stress fractures over the life of the truck. But I'm not an airplane guy so I don't check every inch of the truck every year with an electron microscope either...
  #62
Old 05-05-2011, 11:54 PM
Marauder92V's Avatar
Marauder92V Marauder92V is offline
Marauder92V has a good reputation on FTE.Marauder92V has a good reputation on FTE.
Quote:
LOL! I have only experienced one major engine problem in flight (knock on my wooden head). But I wished I had gone over the plane with a x-ray, MRI along with my electron microscope before that flight (it was metal fatigue).
Like I said, definitely want to move on getting one. Just waiting a bit to see how you guys fair... It's a big investment.
  #63
Old 05-06-2011, 09:12 AM
roadkingfl's Avatar
roadkingfl roadkingfl is offline
roadkingfl is a name known to allroadkingfl is a name known to allroadkingfl is a name known to allroadkingfl is a name known to allroadkingfl is a name known to allroadkingfl is a name known to all
I have the 65 gal. Titan tank....It has three straps....I haven't heard any sloshing and at fill up, there was NO back pressure or foaming....Will keep my eyes and ears open though to see if I detect anything abnormal.
  #64
Old 05-06-2011, 09:53 AM
Kep4's Avatar
Kep4 Kep4 is offline
Jäger
Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.
I had a 46 gallon TransferFlow tank on my '05 truck. It was steel, and Line-X coated, and I never heard any fuel sloshing around. Of course, I couldn't hear much over the 6.0 anyway.
I like the 65 gallon Titan, but am waiting to see what TransferFlow comes out with for the long beds so I can compare prices. 37 gallons does not cut it when towing!
  #65
Old 05-06-2011, 10:03 AM
lexustbs's Avatar
lexustbs lexustbs is offline
lexustbs is gaining momentum as a positive member of FTE.lexustbs is gaining momentum as a positive member of FTE.
It does it read bad with about 3/4 of a tank left. Make a quick stop after moving and you can feel the fuel hit the front of the tank. Its like a driveshaft clunk.
  #66
Old 05-06-2011, 10:44 AM
Hey Kep! Thanks for the link! I went to their website. They have the tanks for the 2011 and they are baffled! And get this, $804... How did your 2005 tank hold up? Any problems with it?
I'll be checking them out: Ford pickup replacement tanks
  #67
Old 05-06-2011, 01:24 PM
lexustbs's Avatar
They are steel though. It's been awhile since I've saw a steel tank on a vehicle. Not saying it won't work..... But I'd reather have sloshing than a steel tank.
  #68
Old 05-06-2011, 02:39 PM
Kep4's Avatar
Jäger
The TransferFlow tank worked just fine and the install was reasonably easy to do by myself. I had it Line-X coated because I took my '05 off road alot. The '11 is too big for that, but I'd probably Line-X again if I go with T-Flow. I never had, nor do I foresee, any problems with a steel fuel tank.
T-Flow tanks are usually less than Titan tanks and that's whay I'm waiting to see what the size and cost comparison will be.
  #69
Old 05-13-2011, 09:22 AM
gascan's Avatar
gascan gascan is offline
gascan is gaining momentum as a positive member of FTE.gascan is gaining momentum as a positive member of FTE.
I did some serious miles today, and after taking the gas cap off, there was just a slight vacuum. But nothing like it was before. I think my problem is fixed! marauder, I did notice the instructions have changed on the Titan website. It says something about generation V? I hope there are not baffles. I'll be kinda upset. But I guess thats what you get for early adoption.
Lexustbs, how did you fix your vacuum problem? Was it a larger valve? I noticed the problem today on my truck with the 50 gallon tank. If you used a larger valve can you send me a link to the one you purchased?
Thanks,
gascan
  #70
Old 05-15-2011, 01:44 PM
slamed150 slamed150 is offline
slamed150 is starting off with a positive reputation.
awesome vid
  #71
Old 06-14-2011, 02:41 PM
buckmasters's Avatar
buckmasters buckmasters is offline
buckmasters is starting off with a positive reputation.
For those of you that have asked, I just got an email from a manager at Titan regarding baffles in the tank. Here is what he said:
"Our tank for the 2011 Ford does have a baffle in it. All of the “super series” do. It is a “low fuel sump” designed to allow the trucks to be run when there is not much fuel in the tank. It is not a full baffle, it is about three inches high from the bottom."
I also mentioned that some on here had complained about sloshing in the tank. He said they have not heard much about sloshing in their tanks, but would pass it along to his general manager.
Thinking about ordering this tank today and hope the install goes as smoothly as in Epic's video.
  #72
Old 06-14-2011, 04:06 PM
If you do order one, can you post pictures of what you find inside? I'm curious what these baffles look like.
  #73
Old 06-14-2011, 06:24 PM
roadkingfl's Avatar
Again, I've had the tank in for around 1,500 miles now...It is very quite.
  #74
Old 06-14-2011, 07:34 PM
Quote:
Same here with over 10,000 on the tank. I've never heard a peep or a slosh.
  #75
Old 06-14-2011, 08:49 PM
lexustbs's Avatar
Epic, mine does it under very specific times. Like the stars have to line up for it to happen to me. But its not a big deal at all.
On another note with the tank. We had an emergency at a jobsite last week and I made the 450 mile round trip without stopping for fuel. I know most of you use the tank for towing, but I use it for peace of mind just incase something does happen. Example being, when we had the severe weather last month I thought how great it was to have 50 gallons in the tank knowing if the fuel stations were down I could make it awhile.
F250 6.7 dsl Titan 50 gal tank Greynomad 1999 to 2016 Super Duty 1 12-28-2015 10:41 PM
50 Gallon Titan Tank m-chan68 6.7L Power Stroke Diesel 11 11-23-2015 05:44 PM
Titan OEM Replacement Tank to Increase Range SouthBoundandDown 6.7L Power Stroke Diesel 4 11-26-2014 10:10 AM
Titan 47gal install, not so great grende7581 6.4L Power Stroke Diesel 5 08-28-2012 10:45 PM
titan or transfer flow Percys Armory 6.7L Power Stroke Diesel 3 11-10-2010 04:53 PM
Tags
2011, 50, diesel, engine, f150, f250, ford, gallon, platinum, rc, tank, tanks, titan, ultima, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
