Titan Tank Installation - VIDEO - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 11-09-2010, 11:29 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Curious, why does one wait until the last minute to look for fuel? I know my limits and usually pick up fuel way before I see fumes to get me to a destination.
  #32
Old 11-09-2010, 12:04 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is online now
EpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud of
Quote:
Why wait? Holy smokes, that was the whole problem. When towing, I just didn't have enough range and I cover 200 miles pretty fast and it's about that time the MTE started making me nervous. I said this before but I'd have to stop for fuel before I have to go pee. It's the whole feeling of just getting up a good head of steam and then feeling like you have to stop AGAIN to get fuel. That tended to make me stretch as far as I could which is a bad thing.
There's other things like, the kids are temporarily quiet so I push for another 20 miles before they ask "are we there yet"? Maybe I'm convoying with by buddies who have a Chev and a Dodge and they have larger tanks. In that situation, size does matter. lol
  #33
Old 11-09-2010, 01:18 PM
Great Danes's Avatar
Great Danes Great Danes is offline
Great Danes is starting off with a positive reputation.
I'm with you Epic! My 1700 mile trip with the 8500lb trailer a few weeks ago was quite annoying having to stop every 3 hrs or so for fuel. I will do everything in my power to get this upgrade approved by the "Finance Dept"
  #34
Old 11-09-2010, 02:30 PM
Maxium4x4's Avatar
Each tank has a limit, I just noticed some, like to squeeze the fumes out.
  #35
Old 11-09-2010, 03:28 PM
Trust me... the last thing my family wants me to squeeze out in the truck, is fumes!!
  #36
Old 03-27-2011, 02:24 PM
lexustbs's Avatar
lexustbs lexustbs is offline
lexustbs is gaining momentum as a positive member of FTE.lexustbs is gaining momentum as a positive member of FTE.
Just installed my tank a few days ago. had a few questions.
What are those two blue spouts on each side of the tank that are covered up?
What did you do with your OEM tank and skid plate? Save it just in case, or did you toss it out? Thanks!
  #37
Old 03-27-2011, 09:58 PM
Pimptorious's Avatar
Pimptorious Pimptorious is offline
Pimptorious is starting off with a positive reputation.
I was thinking about getting one of them tanks, but I have a slip tank / toolbox that holds 85 gallons on the back of my truck. I worked it out last night and I have a fuel range of 2600kms. I think I should be good lol.
  #38
Old 03-27-2011, 11:02 PM
porthole's Avatar
porthole porthole is offline
porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.
On my GMC I cleaned it then tossed it.
Then when I sold the truck I had people contacting me asking if I was selling the tank.
Had I kept it I could have easily gotten 5-600 dollars for it and been half way to the new tank.
When the 65 becomes available I'll be keeping the OEM tank.
  #39
Old 03-28-2011, 08:17 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Honestly, I've always wondered about that. Obviously Ford wouldn't have spent the time putting ink to paper if it wasn't important. Guess it's just a mentality that it won't happen to me. Maybe the rubber in the jack distributes the load a little bit?
Ha!
Ford Techs at the factory use this procedure
I am guessing it is in the manual for the legal eagles.
  #40
Old 05-03-2011, 06:41 PM
lexustbs's Avatar
I think I might have a problem with my tank. Is anybody else getting a rush of air when they open their tank to fill it up? I looked under the truck, and the inside of the tank is kinda sunk in? I hope I don't have to drop the tank and check the vent tube. I know its installed right.... I think
  #41
Old 05-03-2011, 06:45 PM
Lex - is it a vacuum in the tank or higher pressure? Does the air rush in or out of the tank when you open the cap?
  #42
Old 05-03-2011, 06:51 PM
lexustbs's Avatar
I think a vacuum. But I could be wrong. Is your tank dented in twards the back just a little?
  #43
Old 05-03-2011, 07:30 PM
I just checked right now and found that there is no air movement when I take the fuel cap off the tank. Maybe your tank vent is not working?
I have the skid plate on my tank so I cannot see if it is deformed in any way.
  #44
Old 05-03-2011, 08:15 PM
lexustbs's Avatar
I just got back from inside and found that the T where the blue hose and the other two join was pointing down (the blue line was angled down then back up) I don't know if this was my problem or not, but I'll give it a shot. It says in the instructions for the vent line to always have a down hill run on it or else it will create a vaccum? It was the side next to the driveshaft that I noticed was caving in a little. Might try to stick a air nozzle in the tank tomorrow to get it back to shape.
trying to fix those hoses while the tank is mounted is nothing short of a miracle. Although my wrist and fingers look all cut up. Better than my fuel tank imploding I guess.
  #45
Old 05-03-2011, 08:31 PM
I just checked the side of my tank, no deformation. If you had a vacuum in the tank, that would explain it. I'd be a little cautious about pumping a bunch of air into the tank though. Not sure if the tank seals or other fuel lines would like that. I'd say just give it a warm day with a full tank and it should straighten out.
I don't know what to think about the downhill hose theory either. I know I didn't do anything special when I installed mine. I'd suspect that little plastic vent at the end of the line first. Mine is easy to get to as it follows the route up onto the spout assembly. It would be a quick test to pull that out and blow in it a bit.
F250 6.7 dsl Titan 50 gal tank Greynomad 1999 to 2016 Super Duty 1 12-28-2015 10:41 PM
50 Gallon Titan Tank m-chan68 6.7L Power Stroke Diesel 11 11-23-2015 05:44 PM
Titan OEM Replacement Tank to Increase Range SouthBoundandDown 6.7L Power Stroke Diesel 4 11-26-2014 10:10 AM
Titan 47gal install, not so great grende7581 6.4L Power Stroke Diesel 5 08-28-2012 10:45 PM
titan or transfer flow Percys Armory 6.7L Power Stroke Diesel 3 11-10-2010 04:53 PM
Tags
2011, 50, diesel, engine, f150, f250, ford, gallon, platinum, rc, tank, tanks, titan, ultima, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
