Electronic shift control module - Ford Truck Enthusiasts Forums
Old 11-06-2010, 02:16 PM
bluegrasselectric bluegrasselectric is offline
bluegrasselectric is starting off with a positive reputation.
Red face Electronic shift control module
I have a 2000 explorer 4x4 & it is stuck in 4x4 lo, does this mod. have a GEM, if so where is it? Please & Thank you!!
Old 11-07-2010, 06:31 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
First off, I assume you ARE stopped with the transmission in neutral and your foot on the brake pedal when you attempt to shift into/out of 4WD LO?
Assure that all 4 fuses controlling the GEM are good. They are #'s 9,10,20,28 in the fuse box under the dash. Also #6 in the nuder hood fuse box.
The electronic module,located behind the glove compartment, controls the operation of the transfer case in response to inputs from the electric shift motor, 4x4 mode switch, Clutch Pedal Position switch, Brake Pedal Position switch, Digital Transmission Range sensor, throttle position output from the PCM, front and rear Output Shaft Speed sensors, and the VSS. Most malfunctions are caused by wiring issues, most common being bad connections in the connectors. Open the glove box, push in on the sides to allow it to drop down and disconnect/reconnect the module connections several times, see if it works properly. Check for poor connections at the shift motor wiring, making sure the ground wire is still connected. If all else fails you can remove the motor and manually shift it back into 2WD. If you don't have an owners manual to identify the fuse locations you can view/download one here: http://www.motorcraftservice.com/pub.../00expog1e.pdf
Old 11-07-2010, 08:30 AM
Smile 2000 Explorer
Thank you so much !
That is exactly what I was looking for.
This is the 1st. 4x4 that I have ever had, It was given to me because it had a bad motor, I replaced the motor, but when I got it running, it is in 4x4 lo.
I'm sure your info will help.
"bluegrasselectric"
Old 11-07-2010, 09:07 AM
ncranchero's Avatar
Sent you an e-mail. Check out the stuff in it.
4X4 Low works no 4X4 high Slapshottr Excursion - King of SUVs 1 12-21-2016 06:52 AM
Brake Line Help 4x2 ? 4x4 hdpegscraper 1987 - 1996 F150 & Larger F-Series Trucks 3 03-08-2015 08:49 AM
Will a 400 4x4 Oil pan fit a 4x2? 691/2F350 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-21-2013 07:13 PM
1998 F150 4x4 will not engage goodtobeeme 1997 - 2003 F150 4 12-28-2010 06:44 PM
66 f100 4x4 conversion mustang_gt_350 1961 - 1966 F-100 & Larger F-Series Trucks 5 07-15-2009 01:23 AM
Tags
1991, 2000, 4x4, 94, bronco, control, electric, electronic, explorer, f150, ford, ii, module, ranger, shift
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
