05/6.0 glow plugs - Ford Truck Enthusiasts Forums
05/6.0 glow plugs
Old 11-06-2010, 12:42 PM
sleddrunner1 sleddrunner1 is offline
sleddrunner1 is starting off with a positive reputation.
05/6.0 glow plugs
I have a 2005/250 6.0, it resently started jugging when started. Have been told that the glow plugs are going out.
Where are the location of the glow plugs?
Mike
Old 11-06-2010, 02:30 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Welcome to FTE!
The glow plugs are usually pretty reliable. Chances are that your problem lies elsewhere.
Can you describe in more detail what is happening (starting, idling, power, etc)?
Can you see if you have any codes.
Old 11-06-2010, 04:57 PM
I call it jugging, it sound like rough idle when cold then smoothes out when she warms up. I can even plug it in, block heater, and she'll do the same thing.
Old 11-06-2010, 05:10 PM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
Do a search for injector sticktion. Sounds like that is possibly your problem. Could be many other things as well, but as mark said the gp don't go out very often.
Old 11-06-2010, 05:46 PM
bismic's Avatar
Oil weight is important (15W40 could be too thick in winter if your injectors have a little stiction going on). Many recommend a 5W40 or 10W30 oil for winter. Don't go too long between oil changes. Flash updates to the processors help some w/ stiction and a product called Rev-X is said to be effective.
Old 11-06-2010, 09:58 PM
I have used amsoil, 5W30, since new w/bypass filter system, running three filters. I have also put a banks otto mind chip w/4" exhaust. The truck has 75,000 miles. No codes are found. It just starts rough until warm.
Old 11-06-2010, 10:08 PM
bismic you qouted-
Stiction is a condoition that happens over time.
There is a small spool valve in the top of the injector that controls the flow of high oil pressure fed to the intensifier piston in the fuel injector. That spool valve only moves .017", back and forth, on and off every time the injector fires. Many factors play in to how well that valve works such as, oil temp, oil quality, normal wear, ambient temp, and many others. As this valve ages it polishes itself inside the bore of the spool valve and as the spool valve slams back and forth it can set up the condition like a suction cup, hanging the valve to one side or the other. This uncommanded uncontrollable condition is called stiction. Mostly its a rough run cold condition but in severe cases it can be a no start or pretty harsh misfire condition. Oil that stays inside the valve on a hot engine shutdown and is allowed to cool slowly in the injector can aggravate the condition on restart.
How does one check for this?
Old 11-06-2010, 11:23 PM
bismic's Avatar
You pretty much have to have the Ford diagnostic equipment.
Glow plugs,relay and harness Codyg1388 1999 to 2016 Super Duty 0 10-08-2015 07:01 PM
05 6.0 need to crank twice to start aaronlaaron 6.0L Power Stroke Diesel 7 08-23-2015 09:31 AM
05 6.0 f350. Starts on 2nd crank aaronlaaron 1999 to 2016 Super Duty 0 08-21-2015 02:24 PM
GLOW PLUG REPLACEMENT fancyvern 6.0L Power Stroke Diesel 2 12-29-2012 01:39 PM
GLOW PLUG CONTROLLER LOCATION MWILLIAMS 1999 to 2016 Super Duty 2 12-23-2010 12:26 PM
Tags
05, 2005, 60, diesel, enthusiasts, ford, forum, glow, glowplugs, plugs, powerstorke, powerstroke, truck, wheres, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
