Sudden Loss of Power While Driving
I have a 2002 F-250 with a 7.3 with 223,000 miles, automatic transmission, 4x4. Recently, the truck has started randomly losing power while going down the road, usually when I'm going about 45-50. It doesn't die, just kind of hiccups. I can take my foot off the pedal and come right back to it, and it's like nothing ever happened. Any ideas?
Is it at about the same throttle pedal area? Could be a bad spot in your pedal sensor. Updated pedal assembly AND mount needed for that(Riffraff), or cleaning of old one.
I have a friends truck I did a zf6 swap in recently, had a spot at 42-44% throttle input, drops power and bucks, goes away if you mash it or let off. I can see the input % on the edge monitor.
Ford 6.0
I’m having the same issue with my F250 Harley Davison 2004
I was right down the road and lost power prior to that I had to replace four injectors and ran and then lost power going down the road and I had somebody come out and tell me that the other for injectors we’re going out and I replace them for and it’s doing the same thing
Probably will want to go to the 6.0 forum and start a new thread. Best of luck.
Thank you
I’m new to this site wasn’t sure where I go or how do I do it but I appreciate it yes and it does have the 6.0
No problem. In case you haven't found it there is a drop down at the top of the page. Find the Diesel group then find the 6.0 forum. Good luck again
duct tape F-150
25
05-10-2017 08:12 AM
