aftermarket sparks plugs for 5.4L - Ford Truck Enthusiasts Forums
Old 11-06-2010, 12:56 AM
allen07ford150 allen07ford150 is offline
allen07ford150 is starting off with a positive reputation.
just wondering i have a 07 5.4L in my f150 with 30,000 miles on it. it runs fine but want to change the sparks for two reasons one i don't want them to get stuck in the cyl. heads and break off and i want to upgrade a liitle bit so looking for some good ideas on some good aftermarket spark plugs for a stock engine any ideas would be welcome thanks
Old 11-06-2010, 01:03 AM
ruli00's Avatar
ruli00 ruli00 is offline
ruli00 is starting off with a positive reputation.
I don't think the 07-08 have the spark plug issue.
Someone please correct me if I am wrong.
-ruli00
Old 11-06-2010, 08:05 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
It would depend on the build date. Around September 2007 the revised cylinder heads were used. The exact date is on a thread from a year or more ago. So all 07 and some early 08 5.4L's could have the spark plug issue.
Old 11-06-2010, 09:07 PM
thanks for that i kinda of thought that my engine was built in early june so i still have the old cyl. heads any idea on spark plugs that are built any better then the motorcraft ones and preform better or should i just stick with motorcraft ones????
Old 11-06-2010, 11:45 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Quote:
Stick with Motorcraft. There's something about this 5.4 that really likes the Motorcraft parts (filters - oil & air, plugs, etc)
Old 11-06-2010, 11:52 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
The ignition is very sensitive to the plug resistance.Search for the issues people have had when they have tried bosch and NGk plugs just to have to do it a second time with OEM plugs.
Old 11-07-2010, 12:12 AM
thanks for all the feed back I have noticed that people have seemed to have lots of problems with aftermarket parts on the engines it seems like ford did its home work on these 3 valve engines
Old 11-07-2010, 03:14 AM
svt2205 svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
Regarding the updated heads/plugs, look for brown boots on the COPS (coil on plugs) for the revised and improved parts. If you've got those, you'll have an easier time with the plug change.
There are many who have had great sucess with Champion plugs, so don't rule that out as an option.
Old 11-07-2010, 02:16 PM
ok so if the boots are brown on the cops it has the newer style parts cool thanks for that i will make sure and look for that.
Old 11-19-2010, 10:53 PM
ruli00's Avatar
Yes! I have Brown boots.
Thanks for the info
-ruli00
Old 11-20-2010, 03:51 PM
Still Smoking's Avatar
Still Smoking Still Smoking is offline
Still Smoking is starting off with a positive reputation.
I had the plugs changed in my 04 f150 with the 5.4 a few months back and they put in autolite double platinum plugs. My truck ran like crap. They couldnt figure it out. Another mechanic put in motorcraft and the truck ran like a champ. I would not putting anything back in the motor besides OEM.
Old 11-21-2010, 03:14 AM
There are only 4 different brands that are available for our 5.4 3V, at least the last time I looked. Those are Motorcraft, Autolite, Champion and Brisk. Champion and Brisk each have a similar design where the Motorcraft and Autolite are the same design as the factory plugs.
The key with this stuff is follow the TSB, latest and greatest is TSB 08-7-6. Some are using smaller cordless impact drivers to remove the plugs (not sure if the engine is hot or cold) with sucess. Have the Lisle tool handy and you should be just fine regardless of the removal method you choose.
Old 11-21-2010, 05:54 AM
Diesel Man 03 Diesel Man 03 is offline
Diesel Man 03 is starting off with a positive reputation.
If the new sparkplugs( whatever brand) are made for that engine they should work.The engine doesn't know which ones are factory or not.
Old 11-21-2010, 12:14 PM
Huntersbo Huntersbo is offline
Huntersbo is starting off with a positive reputation.
At 49,whatever-thousand miles I pulled my spark plugs and put them back in. I did not want them to get stuck the heads. They were factory Motorcraft spark plugs. The truck then ran terribly nasty. The engine and transmission shook voilently. I made haste getting home but drove gently. On the way home I paid $65.00 for 8 Motorcraft spark plugs. That night I completely dismantled the ignition system. I cleaned it meticulously and put in the new spark plugs with anti-sieze.
Where did all this low end torque come from? My truck never really had that off idle torque. It always ran great from 2,000 to 5.000 rpm. Now it comes to life at 1,500 rpm. The mid-range did not change. At 5,200 rpm when the gas pedal is floored the tires generally break loose a little and always have.
Disclaimer: I had a professional cut into my Y-pipe and weld in my $50.00 junkyard 3" pipe and Magnaflow that I got off a Silverado. It is true 3" single exaust.
Question about 07 5.4 cylinder heads Luckett35 Modular V8 (4.6L, 5.4L) 1 07-28-2016 05:36 PM
Spark Plug Coils makthenif 1997 - 2003 F150 6 04-24-2014 08:49 AM
5.4 3v Spark plugs Bubba Jim Modular V8 (4.6L, 5.4L) 9 02-03-2014 09:45 PM
Best plugs for 5.4L docweld 2004 - 2008 F150 22 02-10-2013 02:41 PM
tachometer on 5.4L engine terragate Modular V8 (4.6L, 5.4L) 3 01-04-2002 04:41 PM
Tags
07, 2010, 54, 54l, aftermarket, champion, f150, ford, good, heads, lightning, liter, plug, plugs, spark, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
