off topic but i need a little help
3.4 Torque Specs
3.4 Torque Specs
These are directly from the GM service manual.
Accelerator Control Cable Bracket Bolt – 18lb.ft.
A/C Compressor to Front Cover Bolt – 37lb.ft.
AIR Pipe – 15lb.ft.
Brace Bracket to Rear Engine Mounting Bracket Nut – 35lb.ft
Camshaft Carrier Bolt – 20lb.ft.
Camshaft Cover Bolt – 97lb.in.
Camshaft Carrier Thrust Plate Bolt – 89lb.in.
Camshaft Carrier Thrust Plate Cover Bolt – 89lb.in.
Camshaft Drive Belt Cover Bolt – 89lb.in.
Camshaft Drive Sprocket Bolt – 81lb.ft.
Camshaft Timing Belt Idler Pulley Bolt
Torque Angle Method – 11lb.ft. + 37*
Hand Method 37lb.ft.
Camshaft Timing Belt Tensioner Bracket Bolt – 37lb.ft.
Camshaft timing Belt Tensioner Pulley Pivot Bolt –
Torque Angle Method – 11lb.ft. + 40*
Hand Method – 37lb.ft.
Camshaft Timing Belt Tensioner Side Plate Bold – 18lb.ft.
Clutch Pressure Plate Retaining Bolt – 18lb.ft.
Connecting Rod Cap Nut – 37lb.ft.
Coolant Bypass Nut – 18lb.ft.
Coolant Inlet Housing Bolt – 20lb.ft.
Coolant Outlet Bolt – 97lb.in.
Coolant Pump Bolt – 97lb.in.
Coolant Temperature Sensor – 13lb.ft.
Crankshaft Balancer Mounting Bolt – 79lb.ft.
Crankshaft Main Bearing Cap Bolt- 37lb.ft. + 75*
Crankshaft Main Bearing Cap Stud – 37lb.ft. + 77*
Crankshaft Oil Deflector Nut – 18lb.ft.
Crankshaft Pulley to Crankshaft Damper Bolt – 37lb.in.
Crankshaft Position Sensor Bolt 71lb.in.
Cylinder Head Bolt (Special Sequence) – 37lb.ft. + 90*
EGR Tube Assembly Bolt – 18lb.ft.
EGR Valve Assembly Bolt – 18lb.ft.
Electronic Ignition Module Assembly Bolt/Stud – 18lb.ft.
Electronic Ignition Module Assembly Nut – 18lb.ft
Engine Block Coolant Drain Plug – 14lb.ft.
Engine Block Oil Gallery Plug – Center Rear – 24lb.ft.
Engine Block Oil Gallery Plug – To Oil Filter – 24lb.ft.
Engine Mount to Bracket Nut – 35lb.ft.
Engine Mounting Bracket to Engine Bolt – 43lb.ft.
Engine Mounting Bracket to Transaxle Bolt – 43lb.ft.
Engine Oil Level Sensor Stud – 89lb.in
Engine Oil Manifold Bolt – 20lb.ft.
Exhaust Crossover Nut – 18lb.ft.
Exhaust Crossover Stud – 80lb.in.
Exhaust Manifold Heat Shield Nut – 116lb.in.
Exhaust Manifold Nut – 116lb.in.
Exhaust Manifold Stud – 13lb.ft.
Flywheel to Crankshaft Bolt – 60lb.ft.
Front Cover Bolts (Large) – 35lb.ft.
Front Cover Bolts (Small) – 20lb.ft.
Front Cover to Engine Lift Hood Bolt – 18lb.ft.
Front Engine Lift Good to Right Camshaft Carrier Bolt – 37lb.ft.
Front Engine Lift Hook to Right Cylinder Head Bolt (Access Through Front Cover) – 37lb.ft.
Front Engine Mounting Bracket to Engine Bolt – 63lb.ft.
Fuel Injector Sight Shield Nut – 89lb.in.
Fuel Pipe Slip Bolt – 62lb.in.
Fuel Pipe Retainer Screw - 62lb.in.
Fuel Rail Assembly Bolt – 89lb.in
Ignition Coil Bolt/Screw – 18lb.ft.
Ignition Coil Nut – 18lb.ft.
Intermediate Shaft Belt Sprocket Bolt – 96lb.ft.
Intermediate Drive Shaft Retainer Screw – 89lb.in.
Knock Sensor – 15lb.ft.
Lower Intake Manifold Mounting Bolt – 20lb.ft.
Oil Cooler Connector – 30lb.ft.
Oil Cooler Hose Fitting – 18lb.ft.
Oil Distribution Cover Bolt – 20lb.ft
Oil Filter – 12lb.ft.
Oil Filter Fitting – 49lb.ft
Oil Level Indicator Bolt – 89lb.in.
Oil Pan Baffle But – 18ft.lb.
Oil Pan Bolt – Except Rear – 97lb.in
Oil Pan Bolt – Rear – 18lb.ft
Oil Pan Nut – 97lb.in
Oil Pan Stud to Cylinder Block – 89lb.in.
Oil Pressure Switch – 24lb.ft.
Oil Pump Cover Bolt – 89lb.in.
Oil Pump drive Clamp Bolt – 27lb.ft
Oil Pump to Rear Main Cap Bolt – 40lb.ft.
Power Brake Booster Vacuum Pipe Fitting – 13lb.ft.
Power Steering Pump to Bracket Bolt – 25lb.ft.
Rear Intermediate Shaft Cover Bolt – 89lb.in.
Rear Engine Mount Strut Bracket Bolt – 60lb.ft.
Rear Engine Mounting Brace to Engine Bolt – 76lb.ft.
Serpentine Drive Belt Tensioner Bolt – 40lb.ft.
Spark Plug
New Cylinder Head – First Time Installation – 18lb.ft.
Non First Time Installation – 11lb.ft.
Spark Plug Wire Support Bolt – 89lb.in
Throttle Body Heater Outlet Nose Nipp13lb.ftle -
Timing Belt Cover Bolt – 89lb.in
Timing Chain Tensioner Bolt – 18lb.ft
Torque Strut and Engine Lift Bracket Bolt – 52lb.ft.
Upper Intake Manifold Mount Bolt – 97lb.in.
Upper Intake Manifold Retaining Bolt – 20lb.ft.
Upper Intake Manifold Retaining Nut - 20lb.ft.
Water Inlet Fitting to Front Cover – 13lb.ft.
3.4 Torque Specs
AIR Pipe – 15lb.ft.
Spark Plug
I had to do my moms head gasket on her Pontiac Gran Scam GT also.
Here are some pictures of how some stuff went back on. Let me know. I may be able to help. I took a bunch of pictures so i can remember how things went back on. Which i had to use a bunch of times. Brackets/wire harnesses etc.
Whoops.. Can't attach a .zip file. If you need them let me know i can shoot them over by email.
i have replaced many intake gaskets on 3.4s i just could not remember the torque specs. Im in larame wy and no one in town could look the specs up for me. Thanks i really appreciate it. i need to get the car done today it is supposed to start snowing the beginning of this week and i still have to do some work on my truck too.
medicpg
12-24-2009 09:11 PM
79rangersc
07-20-2003 11:36 PM
73, coil, conversion, damperpulley, deisel, direction, electronic, ford, ignition, nut, powerstroke, sensor, size, temp, thread, yblock
