Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-05-2010, 09:14 PM
our83 our83 is offline
Garage is empty, add now
our83 is starting off with a positive reputation.
temp sender
Anyone know for certain ?? Is a 72 Cleveland temp sender electrically compatable with the 1966 Ranchero dash. ???
  #2 (permalink)
Old 11-06-2010, 11:24 AM
gfw1985's Avatar
gfw1985 gfw1985 is online now
Amatuer Restorer
1966 Ford Bronco
gfw1985 has a great reputation on FTE.gfw1985 has a great reputation on FTE.gfw1985 has a great reputation on FTE.gfw1985 has a great reputation on FTE.gfw1985 has a great reputation on FTE.
All the old Ford gauges used 10-73 ohm operating range. Fuel, oil pressure, temp makes no diff. Only diff in senders would be for either mechanical gauge or idiot light.
__________________
66 Bronco Half Cab, 203ci I6, CI aluminum head and intake, Isky 256/256 cam, Keith Black pistons, Clifford header, Holley 390cfm 4v, 9.7:1 comp, DSII ignition
  #3 (permalink)
Old 11-06-2010, 01:48 PM
Temp sender
Thanks GFW1985. Where did you find the source of info. ?? Can I bench test senders to determine the resistance ? If so, How.
  #4 (permalink)
Old 11-06-2010, 02:51 PM
gfw1985's Avatar
Amatuer Restorer
1966 Ford Bronco
Ohmeter. You can check the resistance between the wire term post and ground with still in vehicle. You should see it change as temp heats up. 73 ohms would be cold and resistance will drop as it heats up. Grounding the senders wire will peg the gauge to check that portion of the circuit. My source is restoring these old vehicles for the last ten years. Mainly 66-77 year range. Electrical gauges are mostly the same, just different faces and type of sender. Ford used one standard, Chev another etc. All the Ford gauges can be checked by grounding the sender wire, just not for too long, as they have an IVR, instrument voltage regulator, supplying voltage to them. The idiot light senders just supply voltage to the light when the senders value reaches a certain point, a switch for all entensive purposes.
__________________
  #5 (permalink)
Old 11-06-2010, 08:33 PM
temp sender
Thanks again. I did test in the manner indicated. I was not able to come up with 73 in fact the cold readings were more like 0.46. However I checked just after the engine started warming and got 62. Further along it got lower and finially came in at 10.3 at 179 degrees (in tank). Now if I only knew where the needle is supposed to point I'll have it made.
Thanks again, Ken Liden
  #6 (permalink)
Old 11-07-2010, 06:06 AM
gfw1985's Avatar
Amatuer Restorer
1966 Ford Bronco
Thats the kicker. They weren't known to be overly accurate to start with. Better than idiot light, but not as good as mechanical gauges.
__________________
Tags
1967, ford, ohm, ranchero, range, resistance, sender, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
