1964 ranchero wiring diagram
I have a 1964 ranchero with an alternator. I need the wiring diagram for
this application. I have one from Dearborn Classics, but it only shows the
diagram for the generator. The vehicle appears to have been equipped
with the alternator from the factory. Thanks in advance for any help you
guys can give me. Dan.
Received 3,103 Likes
on
see if you can find a wiring diagram for a 65. they are the same thing.
a very good source for falcon and ranchero info is www.tffn.net.
I live up in Everett Wa and the local lib. has a computer that is dedicated for auto repair info as well as a large selection of auto repair manuals with wiring diagrams you don't live that far from Seattle so check your local lib. to see if they have the info. if not let me know and I'll check here and if its here then I'll send them to you. BTW i own a shop man for 66 Econolines and it has the wiring diagrams for the vans witch should be very similar
on
on
Thanks for your help guys. I found an ad for classic car wiring .com. I am going to contact them and see if they have what I need. I took the car off the jackstands 10/18/10 and test drove it 10/20/10. It doesn't want to idle so it was an exciting ride. I'm getting the carb rebuilt today, so hopefully that will fix the problem.
Thanks again, Dan.
Thanks again, Dan.
I have a 65 ranchero,alot of the mustang driveline and suspension are the same! the wiring is the same,on everything i have messed with elec,the 65 mustang or falcon wiring diagram will be same.tons of parts out there for stangs not so much for us,but pretty much only difference is body panels! good luck
on
everything else is different.
check out WWW.tffn.net.
it is all about ford falcons, and ranchero's up to the body change in 66.
while it is true that the mustang was built off the 64 falcon platform, there are so many little differences, that it will drive you crazy trying to use mustang specs on a falcon.
as an example, the falcon engine bay is 1/2 inch narrower than the mustang. no big deal, rite?? well try putting a set of 1965 mustang 289 high performance manifolds on a 65 289 falcon.
the only way they will fit is if you take a big hammer to the spring towers. and then you will need to modify shift linkage if you have a column mount shifter.
Badmrscary
05-22-2016 05:04 PM
rcdnev
03-13-2016 11:09 AM
danlee
22
12-04-2009 11:07 PM
