1987 Ford 460 getting no fuel to the carb - Ford Truck Enthusiasts Forums
Old 11-05-2010, 04:34 PM
synergy141 synergy141 is offline
synergy141 is starting off with a positive reputation.
Hi, I have a 1987 Ford Econoline Motorhome with the 460 carb'd motor. It was running fine all summer went to start it and now it won't start. I dumped some fuel into the carb and it will run for 1-2 seconds until the fuel burns out. When I pump the gas there is no flooded fuel smell. I has been sitting 2 months so something may be clogged somewhere?
Old 11-05-2010, 05:03 PM
Terry S's Avatar
Terry S Terry S is offline
Terry S is starting off with a positive reputation.
Check Fuel filter and fuel pump first.
Old 11-05-2010, 07:12 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
This is a easy one, your fuel pump has failed.
A tell-tale sign of failure is a oil leak from the fuel pump, not a bad job on the 460.......anyone with modest mech skills can do it easily.
Old 11-05-2010, 07:23 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
I dont know w the econlines but the f-series has a electric fuel pump un 87 on the carb 460
Old 11-05-2010, 07:32 PM
Old93junk's Avatar
Quote:
You bring up a good point, I am NOT 100% sure if its a mechanical fuel pump or electrical. On most of the Class C ford motorhomes I have worked on, the fuel pump is mechanical and mounted in the normal place, however 87 was the last year of the carb, they may have gone electrical on the 1 ton van chassis.
Old 11-05-2010, 07:43 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Brad and I will argue this back and forth, but I KNOW how my truck was delivered.
My '87 has a mechanical pump.
A carb with recirculating electric pump is called 'hot fuel handling' and usually incorporated where the truck was delivered to a climate known for vapor lock.
Check to see if there is gasoline in your oil if you suspect that a mechanical pump has failed.
Old 11-05-2010, 08:09 PM
YUP YUp
My fried bought a 87 f350 dually and i t had no mechanical pump but a electric one. The relays constantly went bad. That and there vas an overfueling valve right on the carb that returned unneededd fuel to the tank so not to flood the engine. That thing to a crap every other year and would starve the engine when pulling hills w hay wagons
Old 11-05-2010, 08:39 PM
pedant
I think it was just a plot by Ford to use up the 8,000,000 two piece pump eccentrics they still had, stashed in a warehouse somewhere.
It may be a sign of which line it rolled off of.
As for your tale of a WFO 460 being underfueled by a low pressure electric pump, well, I just can't believe it......
Old 11-06-2010, 08:09 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1986/87 E/F250/350 460: E5TZ9350E .. Fuel Pump-inc. mounting gasket.
Old 11-06-2010, 02:23 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
There's also several electric pumps listed for that vehicle-
E6UZ-9H307-B
E6UZ-9H307-G
E6UZ-9H307-J
E6UZ-9H307-F
different ones depending on how the vehicle is equipped.
On a 460 motorhome my guess would be an electric pump, but you'll have to look to find out for sure. As previously stated, the relays are problematic, so that could be an issue.
Old 11-06-2010, 10:24 PM
GLR's Avatar
GLR GLR is online now
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
subford has a great trouble shooting post "no fuel pressure 87 F250 460cid carb non EFI" I found a bad low oil pressure cut (shut) off switch. The post indicates jumping across the wiring plug-in to start trouble shooting. Switch is located back off the engine near the oil gauge sending unit. Easy to get to on the van.
1987 460 dies after 30-40 seconds Menoche 1987 - 1996 F150 & Larger F-Series Trucks 12 07-29-2016 05:41 PM
Engine dies after 30 seconds or so Menoche Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 07-23-2016 05:15 PM
please help Curt Hurst 1987 - 1996 F150 & Larger F-Series Trucks 10 07-31-2015 04:21 PM
460 Hard Start docpec1 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 13 12-02-2009 09:35 AM
1987 f250 fuel delivery problem; no fuel delivered SBANANA1 1987 - 1996 F150 & Larger F-Series Trucks 4 03-12-2009 09:08 AM
Tags
1987, 460, 87, carb, f250, f350, ford, fuel, gas, handling, hot, mechanical, pump, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
