Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-05-2010, 01:42 PM
65f100CoryE. 65f100CoryE. is offline
Garage is empty, add now
65f100CoryE. is starting off with a positive reputation.
87 Mustang 2.3L to '92 2.3L
just looking for some swapablility and insite.
Let me start with the history.
I picked up an 87 mustang in a trade for a couple of old sleds. The motor in it turned out to use more oil than gas and started to smoke really bad.
I had given to me a '92 motor for free and the story was that a bearing had ceased... well I took it apart and discovered the oil pump pick up tuibe completely clogged, I pulled the entire motor apart to find it in very good condition other wise and rebuilt it with standard bearings and rings.
now the problem comes is the DIS / dual plug thing. I was told by 3 different sources that I could bolt on the '87 intake and put the '87 distributor in and run it like a normal older 2.3 using only the 4 plugs on the exhaust side....NOT the intake/head is completely different.
Is there a way to use the '92 intake plenum with the old school TFI distributor and injection wiring without rewiring the enire ECM etc?
I am trying to avoid pulling apart my freshly rebuilt motor to replace the head with an older head. is this possible. any help would be apreciated.
thanks
Cory.
__________________
Cory
65F100 390 4spd ported heads, comp XE-274 cam, edel RPM intake, headers.
66F100 460 C6 headers and mild cam
74 Maverick 2door 302 C4 Auto Comp XE-262 cam
78F150 SuperCab 400 C6 Auto
96F150 Reg Cab 4x4 5spd 5.0 Mass Air
  #2 (permalink)
Old 11-30-2010, 01:04 PM
mustangman mustangman is offline
mustangman is starting off with a positive reputation.
yeah those aluminum panned 2.3 had a problem with the oil pan gaskets breaking up and plugging the oil screen,,,i have a spare 2.3 with the alumnum pan , still havn't opened it up to take a look at the screen but i will for SURE,, the guy said it ran perfect he did the 5.0 swap, but again that gasket has to be changed for sure,,, you need to swap in the old 87 intake/head as the distributor will hit the newer intake, i think i just posted in your other post you made not sure,,,did you do this swap yet? its been a while since iv been here
  #3 (permalink)
Old 11-30-2010, 02:37 PM
That was me and yes I have completed the motor job. I ended up using the 92 motor with 87 head but with the roller set etc. I used the 92 aluminum pan with the 87 type gasket and some sealer on it. my little car has the full oil pressure guage and I watch it closely on all of my "older vehicles" a soon as it goes a bit lower than expected I am always on the lookout and checking on things. thanks for the input.
__________________
Cory
Tags
23, 23l, 87, 92, clogged, dis, ect, ford, mustang, mustangs, oil, pan, pickup, removal, www87mustangs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
