7.3 power stroke hard to start in the cold weather - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-05-2010, 07:25 AM
kc0ti1002 kc0ti1002 is offline
kc0ti1002 is starting off with a positive reputation.
Now that it is getting cold I'm starting to have starting problems. The engine just cranks and cranks, to the point were smoke is coming out of the exhaust. If I crank in short burst, the engine will eventual start. can any one help.
Old 11-05-2010, 09:50 AM
Technocrsr's Avatar
Technocrsr Technocrsr is offline
Technocrsr is starting off with a positive reputation.
That points to the glow plug solinoid,
But take your question to the 99-04 diesel forum and you will be served.
Old 11-05-2010, 10:32 AM
Fishin76's Avatar
Fishin76 Fishin76 is offline
Fishin76 has a good reputation on FTE.Fishin76 has a good reputation on FTE.
Sounds like your GPR is toast. Replacement with a NAPA replacement is about $60, If you get a GPR108 solenoid from Napa, it is about half price, but the oreintation of the terminals is 90 degrees off. I didn't have any problems with the cheaper GPR. All the leads had enough slack to reach.
That smoke you see out of the exhaust is RAW fuel. If you crank it that long to get it, the cold fuel is now cooling the combustion chamber, and it will never light off. the 7.3L's need four things for a successful winter start.
1. GOOD batteries and Cables. Voltages while cranking that fall below 10.5 volts will not power the ECM to start the engine.
2. Fresh ungelled fuel and a clean fuel filter.
3. Fresh oil. Heavily warn oil will not thin out like it's supposed to. That thick oil makes the oil pressure come up slower, slower cranking speeds, and increased cranking time. (the need for number 1 increases.)
4. Working glow plug system. Once your cranking and the oil pressure is up, the sub freezing fuel starts getting injected. Glow plugs will make all the difference in the world......
It was 31 degrees here this morning, two glow cycles, and truck started right up.....
Old 11-05-2010, 11:42 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
at 30 degrees, my 02 will start within 5 revolutions of the engine after the glow plugs cycle.
Hard starting after sitting a few days. JPMallory 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 08-01-2016 08:33 PM
6.0 IPR Issue medic831 6.0L Power Stroke Diesel 11 12-29-2015 10:56 AM
05 f250 6.0 no start hot Amarillo60 6.0L Power Stroke Diesel 4 04-01-2014 11:10 AM
Cold no start armysoopertrooper 6.0L Power Stroke Diesel 6 11-12-2013 04:04 PM
random extended crank times mwkobe Explorer, Sport Trac, Mountaineer & Aviator 11 11-18-2010 07:54 PM
Tags
1999, 2001, 73, 97, cold, cranking, diesel, f250, ford, hard, plug, powerstroke, problems, repair, start, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
