Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-05-2010, 04:27 AM
'88 E-350 '88 E-350 is offline
1969 Volkswagen Sandrail
My Garage
'88 E-350 is starting off with a positive reputation.
Is running WMO a "green" thing to do?
I've had a few discussions with people about my WMO where they get somewhat angry about the pollution I'm supposedly causing, even tho I've yet had one that actually knows if my exhaust is any dirtier because of it.
My belief is that even if my tailpipe emits a little more junk I'm actually being 'greener'. #1-Burning my WMO eliminates the collection, transport, and disposal of it. #2-Every gallon I use is one less gallon pumped, refined, and transported to the gas station for my purchase. I can't say that I was motivated to run WMO for environmental purposes, but it adds to the list of positives for me. I talked to my local smog tech about doing a #2 vs. WMO test for me and hope to do that sometime soon and report back.
Since I don't have any tailpipe tests yet and I know I'm partial to my own decision, I'm just curious to opinions. Assuming it is a bit dirtier, is it still greener???
  #2 (permalink)
Old 11-06-2010, 04:01 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
In a word, No.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 11-07-2010, 01:16 PM
CampSpringsJohn CampSpringsJohn is offline
KY Chapter LDR
Garage is empty, add now
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
My first thought was "Who cares", but you obviously do. In my opinion, you do what you want to do with your truck, regardless whether it's "green" or not. I know there are some potential issues from running anything other than #2, or a commercial grade bio-diesel. I hope you have done your research on the subject. I have read where some folks have jumped in without doing things properly, and have fudged up their engines.
__________________
97 F-Super Duty, PSD, Auto, Swamps Tunes, 365,000 miles, weighs 13,500lbs /e99 F-350 Utility truck. 9' bed. swamp tunes, 6 speed. 299,000 miles /02 F-250, 4X4, PSD, CC, Auto, Swamps tunes, 124,000 miles
Kentucky Chapter Leader http://www.ford-trucks.com/forums/forum151/ John
  #4 (permalink)
Old 11-07-2010, 02:00 PM
My Garage
I did LOTS of research before dumping in the oil, in fact long before even buying the van. This is what I learned from countless hours at the keyboard; nobody knows. I see some reports that it just won't work, it'll only work if it's hot, it'll trash the motor, it'll run fine for a little while, it'll run fine forever, it makes more power, it makes less power.....a never ending supply of opposing opinions. I've run everything from #2 all the way to gear oil mixes in 50-110 degree weather, so far I have nothing concrete to show the difference other than cost to fill. There's a possibility of harder starts and maybe a little more smoke on pure heavy oil. I say possibility because I haven't done enough back to backs to say for sure. I will say I was surprised to see it run on a cold morning on stuff so thick that I got tired of holding the gas can up to the filler. I have few miles on the oil so I'm NOT saying it's safe for the long run.
My real question is whether the total pollution impact is any worse. I've seen many opinions saying tailpipe emissions are worse with oil, but none quantified by an emissions test so I guess that'll be on me to find out. Will it make me stop? Maybe if the tailpipe emissions are really bad. I hope to make time to run a test tomorrow.
  #5 (permalink)
Old 11-07-2010, 08:43 PM
KY Chapter LDR
I assume that you are mixing some #2 with the oil aren't you? Or are you running it straight? I would guess that if you are filtering out all the metals, and other fine particles that could damage the injectors or cylinders, it should run OK. If it is real thick I could see that causing problems in the fuel delivery system.
__________________
  #6 (permalink)
Old 11-08-2010, 10:11 AM
My Garage
I started out with about 20% oil and kept moving up, now at 100% minus whatever #2 mixes in when I switch tanks. I filter through a 1 micron absolute bag filter. I'm currently setting up (or trying to) a centrifuge. I've been shutting down on #2 just to give things a chance to clean up a little between oil runs. I have no idea if that'll make a difference, but it makes me feel a little safer. I don't warm up on #2 anymore, I switch it as soon as it starts.
  #7 (permalink)
Old 11-08-2010, 02:44 PM
My Garage
See thread "WMO emissions test results"!
  #8 (permalink)
Old 12-28-2010, 07:31 PM
ken1mod ken1mod is offline
ken1mod is starting off with a positive reputation.
I think you are doing good for all of us.
Ken
  #9 (permalink)
Old 01-08-2011, 07:19 PM
My Garage
Thank you for the feedback and compliments. I have found that cold starting on high viscosity stuff is really hard. I'd done it previously once and it started pretty well, may have just been lucky. My batteries are getting really weak so that's playing into it as well. I haven't been driving it much lately because the water pump bearings had a bit too much play for my comfort, but the new pump should be in tomorrow so I can start logging some miles again but I'll need new batts. really soon; damn, always something.
  #10 (permalink)
Old 01-09-2011, 08:21 AM
armstrongfordtrucks armstrongfordtrucks is offline
1975 Ford F-250
armstrongfordtrucks is gaining momentum as a positive member of FTE.
I live in Pa, my truck will start down to 35* on new batteries on 80% WMO. I now run 25% WMO 75% diesel until the weather warms up.
__________________
ARMSTRONGFORDTRUCKS
2000 F-350, XLT, CC, 4X4, AUTO. 5" STRAIGHT THRU, 6637, DP TUNER, stock, hi idle, 60 tow, decel, 80 econo, 120 race, BED LINER, GAUGES. FRESH RUST FREE FROM HUSTON TEXAS.
Tags
60diesel, cleaning, diesel, engine, ford, green, harder, runnig, running, rus, start, superduty, tank, thing, truck, wmo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
