1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2008 F250 Cruise Control stopped working
Old 11-04-2010, 02:48 PM
Sugars Pop's Avatar
Sugars Pop
Sugars Pop is offline
Cool 2008 F250 Cruise Control stopped working
Tried the cruise this morning and it wouldn't come on. Checked the owners manual for fuse or relay location and it's not listed. Can somone please provide me the fuse/relay number for the cruise control or other suggestions on trouble shooting the problem. Have several long trips coming up shortly so I need to get it fixed ASAP.
Thanks
Old 11-04-2010, 06:54 PM
Lee_Bay's Avatar
Lee_Bay
Lee_Bay is offline
If your airbag light is staying on, then it's probably your clockspring.
Old 11-04-2010, 07:34 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
Is it under warrenty?
Check the basic things first.
If its a 6 speed, will it start with the clutch pedal out?
Are the brake lights on even when your not pressing the pedal?
Have you checked the fuses?
Does the horn work?
Old 11-05-2010, 08:14 AM
Sugars Pop's Avatar
Sugars Pop
The air bag light stays on for about 3 seconds after the engine is started. Horn works. Brake lights are working properly and do not stay on after the pedal is released.
There are about 70+ fuses/relays listed in the manual but it doesn't say which one is for the cruise control.
Old 11-05-2010, 08:49 AM
bill11012's Avatar
bill11012
Ok, well hopfully someone will come along that knows the fuse #. I'm not sure what else its on the same fuse either.
Is it still under waranty?
Old 11-05-2010, 09:11 AM
Sugars Pop's Avatar
Sugars Pop
Truck has 126,000 miles so the warranty ended several months ago.
Old 11-05-2010, 12:52 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
First of all, what engine do you have? On a diesel, cruise functions are entirely controlled by the PCM, so there is no special fuse. On a gas, it's probably fed off of one of the RUN feeds.
Second, try this diagnostic...
https://www.ford-trucks.com/forums/9...ml#post8315477
It will tell you if your cruise switches and clock spring are all good.
Old 11-05-2010, 01:55 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
In 2008 there shouldn't be a Speed Control fuse... it's all part of the PCM. When you activate cruise control, it just transfers throttle input from your foot to an array of sensors. That is the beauty of having an electronic throttle. You don't actually modulate the throttle with the gas pedal, you're simply telling the computer how you want it to modulate the throttle.
one of those sensors must be reading unexpected values.
...you are pressing ON and then SET while traveling over 30mph, correct?
Old 11-05-2010, 02:20 PM
senix's Avatar
senix
senix is offline
Received 1,414 Likes on 1,009 Posts
check your batteries, they have been known to do some wierd things on these trucks. Get them load tested while in the truck. NAPA or Autozone will do it for free.
Old 11-05-2010, 11:25 PM
Neil's Avatar
Neil
Neil is offline
I drive a 2008 Ford van for work. The cruise stopped working on it a while back. The dealer plugged in their fancy computer and started testing the switches on the steering wheel... all were working as they should. He reached down and pressed the brake pedal while watching the computer screen & there it was! Brake pressure switch on the master cylinder was bad. The pressure switch is an additional kill switch for the cruise. If tapping the pedal to activate the brake lights fails to disengage the cruise, the pressure switch will. In my case it was sticking, preventing the cruise from working at all.
Old 02-20-2013, 02:04 PM
Doug Wright's Avatar
Doug Wright
Doug Wright is offline
Brake Pressure Switch
Where is the brake pressure switch on my 2008 F250 Diesel? any pics?
Old 02-20-2013, 02:21 PM
Sugars Pop's Avatar
Sugars Pop
Not sure where the pressure switch is but they ended up replacing a sensor or module on mine for about $275.
Traded this dog in last April after the 3rd fuel pump went out in 180,000 mles.
Old 02-20-2013, 02:23 PM
Doug Wright
Thank you for the reply, SugarPops
MTP55
06-07-2017 03:15 PM
zzyzxroad
2004 - 2008 F150
07-27-2016 07:31 AM
casanova76
1997 - 2003 F150
12-28-2015 12:03 AM
DevilDocTater
09-30-2012 04:52 PM
MikerMan
Electrical Systems/Wiring
09-19-2002 06:24 PM
Quick Reply: 2008 F250 Cruise Control stopped working
