CLEANING INTAKE MANIFOLD - Ford Truck Enthusiasts Forums
Old 11-04-2010, 03:42 PM
PADLER PADLER is offline
PADLER is starting off with a positive reputation.
long story short, i am in the process of doing an oil cooler and a egr delete. (fun job on its own) I have the intake manifold off and it is filled with black junky tar. Just a complete mess. I am waiting for the new parts to get here and am wondering what the best way to clean this is. I was thinks of just letting it sit in some simple green for a few days until the parts came in and then pressure washing it all out. Will giving it a good soak hurt anything or am i better off spraying it down quick scrub and repeating until it's clean.
Also gonna clean the turbo while it's off so any tips on that would be of great help but i am looking for answers to that currently.
Old 11-04-2010, 04:19 PM
hubler13f's Avatar
hubler13f hubler13f is offline
hubler13f has a good reputation on FTE.hubler13f has a good reputation on FTE.
I soaked mine for a couple days in simple green and castrols super clean (wicked stuff) and all of the crap still didn't come out.
If you have a place around you that will hot tank it, take it there and it will remove everything.
Old 11-04-2010, 06:06 PM
High Binder's Avatar
High Binder High Binder is offline
High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.
I tried it and gave up quickly, there really isn't any benefit anyway.
Old 11-04-2010, 06:44 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
Wallmart has "Purple Power" that works really well, its a concentrated degreaser.
Old 11-04-2010, 08:23 PM
rocky1074's Avatar
rocky1074 rocky1074 is offline
rocky1074 is gaining momentum as a positive member of FTE.rocky1074 is gaining momentum as a positive member of FTE.
Quote:
This site will help you with your turbo:
Diesel Technician Society
Also this is the kit I purchased for recondition the turbo. 4C4Z-9V424-AA
It come with everything you will need. I ordered from Ed the Parts Guy
http://www.trademotion.com/partlocat...?siteid=214072
Old 12-14-2010, 11:06 AM
idgara73612's Avatar
idgara73612 idgara73612 is offline
idgara73612 is starting off with a positive reputation.
rocky, what's included in that kit? Is it specialty pieces you can only get thru this kit, or is it just different sanding pads and such that you could get on your own, and maybe save some money?
Old 12-14-2010, 11:22 AM
jasontrucks76's Avatar
jasontrucks76 jasontrucks76 is offline
jasontrucks76 is starting off with a positive reputation.
I spent 5 or 6 bucks at the quarter wash with hot soapy water and degreaser and got it pretty clean. I would bet soaking it in some degreaser first would have been a benifit.
Old 12-14-2010, 11:25 AM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
I just finished oil cooler egr cooler welded, and i tried cleaning mine. I have parts cleaning tank with the flamble stuff in it, crap cleans anything i have put in there. And manifold fit, so i let sit for three days , pulled it out little bit gone but not much. I also use purple power from wally world, repeated spraying and hose downs did a better job. If you could let it sit in purple power i think it would clean it , say a few days
Old 12-14-2010, 11:31 AM
ncdawg ncdawg is offline
ncdawg is starting off with a positive reputation.
Clean Intake
I also wanted to clean my intake when I did my oil cooler/egr delete. I was told by a couple of people on the forum to hot tank my intake and some said not to. I talked to my local ford diesel engine mechanic, and he warned against hot tanking for a couple of reasons. First, some use places use too harsh chemicals that can pit the intake, and they don't get it very clean for the cost. Secondly, it will just re-goo up again in short time and again you don't get your monies worth. I just took some carb cleaner and long nylon brush and cleaned it the best I could. Make sure you wear old clothes because you are going to get covered in some nasty black stuff. On the other hand, if you really do want to hot tank it, I would look over the shops procedures and ask the person doing it a lot of questions. Intakes are not cheap.
Old 12-14-2010, 11:54 AM
Quote:
It would only 're-goo' if you kept your EGR system running but since you deleted it...
Old 12-14-2010, 12:41 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
Have it hot tanked, it will be FINE. Most any local machine shop should be able to do it. With the EGR deleted, it should not re-goo as much.
Old 12-15-2010, 09:40 AM
TheBestKindOfEX's Avatar
TheBestKindOfEX TheBestKindOfEX is offline
TheBestKindOfEX is gaining momentum as a positive member of FTE.TheBestKindOfEX is gaining momentum as a positive member of FTE.
dip dip dip
I recently did ARP studs and took my intake with me to the machine shop when I had the heads checked. My intake was HORRIBLE to say the least. The shop hot dipped it for $25 and it was like new! Dover Heads in ATL is the shiz....
Old 12-15-2010, 04:41 PM
Ford_Doctor's Avatar
Ford_Doctor Ford_Doctor is offline
Ford_Doctor is a name known to allFord_Doctor is a name known to allFord_Doctor is a name known to allFord_Doctor is a name known to allFord_Doctor is a name known to allFord_Doctor is a name known to all
Technically the only real need to have your intake manifold cleaned is for excessive build up around the EGR valve mixer and clogging of the port that goes from the cooler to the EGR valve inside the manifold.
If you are simply replacing the valve and servicing the manifold, scraping vacuuming of the large chunks of carbon followed by some scrubbing with an appropriate nylon brush and a chemical cleaner is all that is needed. As stated, the manifold is going to soot up again if the EGR valve is still in use therefore cleaning it to the point of being spotless is pointless.
Having the manifold hot-tanked is necessary when the EGR port is loaded with crust which is typically a combination of carbon and coolant that eventually breaks off and gets stuck in the EGR valve, hanging it open. This type of build up usually only happens with an EGR cooler failure that has allowed coolant to slowly leak into the cooler. Many technicians will have the manifold tanked when EGR coolers fail. In the past I have seen too many trucks get towed back in because even thought he coolers had been replaced and the technician (myself included) did a great job with the repair, the chunks will continue to break off and get caught in the valve unless they are completely removed.
I have never heard of any ill-effects of hot tanking. Blasting it with degreasers and chemicals and washing it out with a water hose usually brings poor results and unless you are hosing or pressure washing where the run off is drained into a waste collection tank of some sort you will be polluting and making a big mess where you are working. It can get downright ugly in fact. Don't ask How I know...
If you are in the EGR delete gang, having the manifold cleaned will only serve to make you feel good about it but if the EGR is removed from the equation the manifold will remain clean so in that sense it is worth doing.
Rusty passenger side intake manifold Dude-Ford 1999 - 2003 7.3L Power Stroke Diesel 5 04-10-2016 09:47 AM
Intake spacer (elbow) torque spec? Psyclopse Excursion - King of SUVs 0 05-07-2015 02:02 PM
Intake Manifold Cleaning 04scurs 6.0L Power Stroke Diesel 30 11-18-2014 07:00 PM
Painting a intake manifold. SC78f150 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-23-2014 08:31 PM
Oil in the intake manifold thomas5853 6.0L Power Stroke Diesel 5 11-02-2010 09:51 AM
Tags
58, 60, benefits, clean, cleaning, cost, estimated, ficm, intake, manifold, mod, powerstroke, removing, turbo, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
