Alternator Went
Alternator Went
So last night I was going to post here because I was 95% sure my alternator was going out after 135K miles, but decided not to, I will just test it tomorrow I thought. Well I get up and take my mom to the train and to get a bagel. "OK Same symptoms as yesterday, definitely test when I get home" turned into "What else can I turn off to make it home!"
I was about 2.5 miles from home when problems arose. I had my radio on very quiet, and it started kicking out, so I turn that off, maybe .5 miles down the road my voltage gauge drops dead, then some other gauges die another mile down the road, so I turn the dash lights down and the windshield wipers down. Another .5 miles down the road, I notice my headlights are gone and the rest of my gauges, and in the last .5 miles, it was hiccuping, lights on the dash such as the ABS and SRS light came on, but the battery light never came on
So I am sitting at home now and my dad wants to know if we can take it to a garage to get it fixed, or whether to have it towed or not...
Am I right that an alternator is just 1-2 wires, a few mounting screws, and releasing tension on the belt to remove it, and vice versa to put it back? I know you have to remove the intake tube, but thats not a problem, as well as anything else being removed, not a problem.
I did the alternator in my 2000 expedition in the parking lot of an auto parts store. The hardest part was getting the belt back on, I ended up buying a breaker bar just for that and it was still painful. It doesn't help that I had to sit up on the grill and had no leverage.
Just be sure to check the charging fuse. I changed my alternator and battery and STILL had issues. Turned out the fuse under the hood was burned out. I'm not sure to this day whether the alternator was really bad since they couldn't test it (battery was tested and was bad).
If it takes more than 15 minutes to change it, then you have no business ever touching a tool again.
Well my dad decided that I am not smart enough to change the alternator, so he called a tow truck. Being the mental giant he is, he didn't realize he needed a flat bed, so when the tow truck showed up I asked my dad where the REAL tow truck was.
And he says I am the one who shouldn't touch a car...
Ya caught me, I dont feel like typing it out, I dont even like saying it. If someone asks specifically, its my parents trucklet, but if I am just in conversation, I say mine, as in the one I drive. It is much easier to just say "my expedition" than to go through the whole process of how its not mine, but my parents.
...Just be sure to check the charging fuse. I changed my alternator and battery and STILL had issues. Turned out the fuse under the hood was burned out. I'm not sure to this day whether the alternator was really bad since they couldn't test it (battery was tested and was bad).
Bullride_101
Electrical Systems/Wiring
11-07-2013 06:30 AM
speedofmouth
03-10-2005 11:45 PM
