1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Clunk while accelerating from coasting
Old 11-04-2010, 01:47 AM
hansp's Avatar
hansp
hansp is offline
Our 2004 Navigator has developed a pronounced clunk, which is reproducable if you're driving at highway speeds and let off the gas and coast for 5-10 seconds. Then when I step on it, I feel a clunk, almost as if gears were engaging. I'm pretty sure it's the rear, this happens in 2WD (haven't tried it in 4WD mode).
If I accelerate gently, it doesn't make the sound. I'm somewhat mechanical and for those who are familiar with Volvo Outdrives, it's a similar clunking noise when they engage into gear.
I've worked on Volvo's for years, but I'm just not familiar with Ford products and SUV's.
I'm thinking either suspension or in the differential. Any thoughts or ideas ? The car has 98k miles on it, and has generally been taken care of.
Thanks !
Old 11-04-2010, 07:19 AM
Big Greenie's Avatar
Big Greenie
Big Greenie is offline
Temporarily Deactivated
Start by checking the u-joints in the driveshaft. They you could check the play in the ring and pinion. Check the transmission mount, and any mounts in the rear diff cradle.
This may be tricky to isolate because it requires a bit of engine torque to make it happen. Whatever is clunking may not be so loose yet that you can see it or feel it without driving.
Old 11-04-2010, 12:42 PM
1999Expy's Avatar
1999Expy
1999Expy is offline
Had a similar sounding problem last year in my 99 Expy - (https://www.ford-trucks.com/forums/8...eleration.html )
After checking u-joints and driveshaft as suggested here, my issue turned out to be the front transfer case. Replaced with a reman'd one and everything has been silent since . Worth considering....
Old 10-25-2021, 07:51 PM
cddulin87's Avatar
cddulin87
cddulin87 is offline
HELP PLZ
Thanks !
Did you ever figure out the problem causing this issue? I've changed the rear diff, rear axles, engine mounts, transmission mount, rear differential arm mount, u-joints...everything. I can't afford to keep guessing.
Old 04-16-2022, 07:28 PM
soal98's Avatar
soal98
soal98 is offline
cddulin did you ever figure this out? I am in the same boat.
68Flareside240
06-17-2020 10:20 PM
dagray3
11-10-2004 12:59 PM
t_dickie
10-21-2004 02:42 PM
JoeBob1901
01-11-2004 03:40 PM
No_BS
06-05-2003 09:48 PM
Quick Reply: Clunk while accelerating from coasting
