fe bellhousing question - Ford Truck Enthusiasts Forums
Old 11-04-2010, 01:08 AM
trav54 trav54 is offline
trav54 is starting off with a positive reputation.
I have a 66 swb with a 352 3 speed, i'm going to put in a 67 428 with 63 or 64 close ratio toploader 4 speed, will the truck bellhousing work with the 4 speed? havent removed the old three speed yet wonderin if input shafts were different lenghts.
Old 11-04-2010, 10:24 AM
66f-100's Avatar
66f-100 66f-100 is offline
66f-100 is starting off with a positive reputation.
I think I found the answer for you. Look at this link. At the bottom of the page, it says you cannot use the truck bellhousing with a toploader.
Bellhousing ID Chart
Old 11-04-2010, 06:23 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
This chart isn't worth two cents, where is the FE truck info?
What F Series truck had a 351 engine prior to 1977? None.
There is no such ID number of C5TA-6394-A. It could be C5TA-6392-A = C5TZ6392A replaced by D1TZ6392D ... see next line.
There is no such thing as D1TA-6394-AA or D1TE-6394-AA, it has to be: D1TA-6394-BA (D1TZ6392D) = 240/300 = 1965/79 F100/350 & 1965/79 Econoline.
Here is the correct info taken from the 1964/72 & 1973/79 Ford truck parts catalogs:
FE truck 3/4 speed bellhousing marked: C5TA-7505-B = 1965/66 F100/250 2WD / 1966 F100 4WD / 1967/76 F100/350-all.
FE truck 3/4 speed bellhousing marked: C5TA-7505-C = 1965 F100/250 4WD / 1966 F250 4WD / 1965/66 F350.
I've never swapped a top loader into a truck, but since the Ford type 3.03 3 speed manual is the same passenger car/truck, it will bolt up to either bell housing, so why wouldn't the 4 speed top loader do the same thing?
I think whoever made up that chart was either refering to the C5TE-7505-C marked bellhousing, cuz it's different than the only other one, or is clueless.
I didn't see if the passenger car info is correct, cuz it doesn't apply..but it's prolly screwed up as well.
Old 11-04-2010, 09:39 PM
thanks for the info! I hope it works, should be fun when its all done!
5 speed trans bolt up to 4 speed bellhousing stagecall 1961 - 1966 F-100 & Larger F-Series Trucks 6 04-19-2016 08:22 AM
I have 66 F350 300 6 with a 4 speed.I have a 5 speed.Will this bolt up to my bellhousing? stagecall 1961 - 1966 F-100 & Larger F-Series Trucks 0 04-17-2016 07:07 PM
4-speed bellhousing samickguy15 Clutch, Transmission, Differential, Axle & Transfer Case 9 04-09-2015 01:32 AM
Bellhousing to trans pattern wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-15-2012 09:31 AM
4spd bellhousing salf100 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 06-10-2011 04:35 PM
Tags
bellhousing, bellhousings, car, fe, ford, speed, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
