2000 Expedition bypassing the auto-4x4 to make it 2x4? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 11-03-2010, 09:18 PM
ThatFordGuy's Avatar
ThatFordGuy ThatFordGuy is offline
ThatFordGuy is starting off with a positive reputation.
We have a 2000 ford expedition eddie bauer. Its 4x4 selectors have 4x4auto, 4x4hi, and 4x4low. The hull sensors keep acting up kicking it in and out of 4x4 even were just driving on pavement. We want to bypass those hull sensors or something so we can just strictly have it in 2x4 like regular package trucks like my uncles. Anybody know what im talking about or have any suggestions?
Old 11-03-2010, 09:34 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Hull sensors?
What is a hull sensor?
Where is it?
And what do it do?
Old 11-04-2010, 12:46 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Remove the 30 amp fuse #104 from the under hood fuse box. It's okay to leave it out, you just won't have 4WD even if you turn the selector switch, unless of course you first put the fuse back in. Some have gone so far as to setup a switch on the dash to flip from inside the cabin.
Old 11-04-2010, 07:24 AM
orleec's Avatar
orleec orleec is offline
orleec is starting off with a positive reputation.
Quote:
For mpg improvement I suppose? What's the consensus on this, worth defeating the A4WD for a little mpg improvement, if any?
Old 11-04-2010, 08:06 AM
Big Greenie Big Greenie is offline
Temporarily Deactivated
Big Greenie is gaining momentum as a positive member of FTE.
Instead of disabling the system, why not fix it?
BTW, it is not an Eddie Bauer option, all of the '99-01 Expy's used the A4wd as the default setting.
There is no mpg improvement to be had. Without major hardware changes pulling the fuse simply disables the 4wd engagement.
Old 11-04-2010, 09:40 AM
Quote:
Because maybe for either time or financial reasons he is not able to fix it for the moment. Pulling the fuse will allow the truck to be driven until it can be fixed. My guess is that he's just going to need a set of 4 matched tires to solve the problem anyway...that or a wheel sensor.
Old 11-04-2010, 11:11 AM
Well I sure am glad you can read minds
I was just asking the question.
Old 11-04-2010, 02:39 PM
I can't, it's just that he asked how to disable it, not how to fix it. I figured he has his reasons and it wasn't my place to question his motives...unlike some.
Old 11-04-2010, 06:27 PM
madsonp's Avatar
madsonp madsonp is online now
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
Yep, I agree, if he has mismatched tires, that's probably the cause of his problem.
Old 02-14-2011, 11:38 PM
we have all four of the same tires on it. turns out that the front and rear tires are supposed to have different tire pressures (door jam says so) supposed to run one set with 5lbs less pressure than the other. We adjusted that and now it does just fine. no more jumping in and out of 4x4.
Old 02-15-2011, 07:42 PM
madsonp's Avatar
Quote:
I've always run all my tires at the same pressure and I've never had any problems.
Old 02-15-2011, 08:44 PM
Junebug_'s Avatar
Junebug_ Junebug_ is offline
Junebug_ is starting off with a positive reputation.
Fix it! :-)
1991 f150 crank no start awatts18 1987 - 1996 F150 & Larger F-Series Trucks 13 05-26-2016 07:34 PM
F150 King Ranch 3.5 Eco Boost 4WD carlhwv Vehicles for Sale 0 04-09-2016 06:16 PM
Well, not a 6.4 I guess... coreyallan01 1994.5 - 1997 7.3L Power Stroke Diesel 26 02-06-2016 07:01 PM
tranny or transfer case or elecrtic problems or all the above need help Chris Newman Modular V8 (4.6L, 5.4L) 0 11-12-2014 07:55 PM
If you love your truck, post here hull_viper2 1999 to 2016 Super Duty 51 04-03-2011 09:58 PM
Tags
2000, 2003, 2007, 2x4, 4x4, a4wd, auto, bypass, computer, disable, expedition, explorer, ford, hull, sensor, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
