351M or 400 Engine Build Starting Point
Im wanting to go with the 351m/400 powerplant in my truck. I have the original 351m that it came with. It runs fine. I plan to do a mild performance build on what ever I do. All the usual stuff. Intake, cam, 0degree timing, tube headers, etc. Maybe even throw some TMeyer Inc money into it.
Am I better to start off with a 351m block or start looking for a 400? I have the 351m already so can I use that and update it to the 400 internals easy enough and then continue my build? Thoughts? I probably can buy a 400 for a few hundred dollars...maybe thats the better way to start?
Nothing against Tim or his products whatsoever, but you could save some money by buying a 400, and just using the crank from that, or just a crank if you can find one. You can get a 400 for 200$ no problem, I helped a guy tear one down recently when I needed a crank, and he gave me it, 3 heads, and a little grab bag of other stuf for 160$. Pistons though buy from Tim, if you want to go that far with your rebuild.
And yes, the 351M and 400 blocks are exactly the same, a 351M block is a 400 block.
AleX
AleX
MattMac
02-23-2017 08:00 AM
Nolan8976
08-07-2016 11:27 AM
mirage820
07-30-2004 03:32 AM
Dee C.
05-19-2003 10:58 AM
qikbbstang
06-18-2001 07:43 AM
