what does white smoke on warm engine mean? - Ford Truck Enthusiasts Forums
Old 11-03-2010, 12:27 AM
savage250 savage250 is offline
savage250 is gaining momentum as a positive member of FTE.savage250 is gaining momentum as a positive member of FTE.
In previous posts I was wondering if I have an injector failing, but this leads me to another quetsion, how can you have white smoke after the engine is warmed up? If white smoke is unburnt fuel, doesn't that mean the injector is still putting fuel into the cylinder? If it is, why isn't it combusting?
Or does it mean more that the injector isn't putting the fuel in at the right time, so it just gets pumped out the exhaust?
When I rev it up in neutral, it hesitates, and I hear it sputter abit, then puke out a clound of white smoke. Also with new vavle cover harnesses, and new glow plugs, it still sends alot of white smoke at start up, and for the first 20-30 seconds on driving, (temp now is around 40 deg).
Just trying to understand what the white smoke means, when the truck is all warmed up. Thanks.
Old 11-03-2010, 12:51 AM
mndiesel's Avatar
mndiesel mndiesel is offline
mndiesel has a great reputation on FTE.mndiesel has a great reputation on FTE.mndiesel has a great reputation on FTE.mndiesel has a great reputation on FTE.
How about the glow plug relay, is that new? MIne just started smoking again since it cooled off. Did the relay last year and I will do the glow plugs in a couple weeks.....
Old 11-03-2010, 01:29 AM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.
I think white smoke can also be coolant burning. How's your level look? What about the color?
Old 11-03-2010, 07:33 AM
Jmatthews's Avatar
Jmatthews Jmatthews is offline
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
White smoke is LACK of fuel like when your fuel pump is going out. Unburnt fuel is black smoke.
Old 11-03-2010, 06:45 PM
Why does it throw white smoke when it starts cold then? I thought that was the fuel entering a cylinder not warm enough to combust and it is pumped out??
Old 11-04-2010, 01:29 AM
twags6's Avatar
White smoke on startup is the unburnt fuel due to too cool of a combustion temp. I did some reading and apparently that can happen when the engine is also warmed up due to insufficient fuel while running (ex, low fuel pressure or clogged filter). That could be your issue with the hesitation. Got a way to check the fuel pressure while driving? The early PSD's have a mechanical fuel pump in the back of the valley.
Old 11-04-2010, 01:41 AM
Visseroth's Avatar
Visseroth Visseroth is offline
Visseroth has a good reputation on FTE.Visseroth has a good reputation on FTE.
Lack of fuel will also cause a noisy engine.
Hard start with white smoke, bad injectors ??? BigBlackF-250 1999 - 2003 7.3L Power Stroke Diesel 24 05-05-2016 12:02 PM
White/Blue Smoke Until Warm fhafer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 10-25-2013 02:30 PM
Still fighting white smoke!(wrong injectors) McQ Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 06-17-2012 09:33 AM
Diagnosing White Smoke? linus72 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 04-16-2012 08:40 AM
2004 6.0 diesel white smoke stacy h 6.0L Power Stroke Diesel 4 01-10-2012 05:07 AM
Tags
73, 73l, bed, burning, diesel, dump, engine, ford, fuel, mean, powerstroke, smoke, throwing, truck, unburnt, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
