MY 91 7.3 wont shut off - Ford Truck Enthusiasts Forums
Old 11-02-2010, 10:51 PM
thebus1978 thebus1978 is offline
thebus1978 is starting off with a positive reputation.
My 91 wont shut off when u turn the key off. I have to pinch the fuel line to shut it off. Anyone have any ideas?
Old 11-02-2010, 10:54 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Don't pinch the fuel line that will just cavitate the injection pump and cause issues you need to pull the wire off the pump that controls the fuel solenoid. Have you taken the ip apart? Sometimes if the housing is installed wrong it will stay running.
Old 11-02-2010, 11:05 PM
I pulled the top off the pump.and the wires didnt shut the engine off when i unplugged them.
Old 11-02-2010, 11:08 PM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar has a good reputation on FTE.rodneywar has a good reputation on FTE.
the fss inside the ip is probably bad meaning stuck on when was the ip replaced
Old 11-02-2010, 11:14 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
OK so you took the FSS wires off the spade terminal........ that was the drivers side (USA) front IP wire correct.
The engine then still failed to shut down...... sounds like the FSS is fubar.
Private message!!! not possible yet.......
I have a TSB and info as to the correct removal/installation of the IP top cover so you can check the FSS physically.
If you have the top off now.....using 12v wire on the spade terminal and grounding the cover. The FSS should click when power applied/removed. You should notice the movement of the arms too.
Old 11-03-2010, 04:27 PM
hooksetz's Avatar
hooksetz hooksetz is offline
hooksetz is starting off with a positive reputation.
please could someone send me that info too, my truck did the same thing a month ago, my starter switch broke in half. I've replaced the switch but my truck still wont start
Old 11-03-2010, 05:34 PM
NEED PART #
Need a part # for the FSS if anyone knows i would much appreciate it.
Old 11-03-2010, 06:02 PM
hooksetz's Avatar
is yours bad? and how did you check it, plus what is a fss? 'cause my truck did the same thing and I've still not got it started a month later.
Old 11-03-2010, 06:50 PM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
FSS = Fuel Shutoff Solenoid, it's an electrically-actuated valve that when applied power to opens the injection pump's inlet port and allows fuel to flow in the IP. When you shut your truck off you essentially cut power to the FSS, which causes it to snap closed and kill fuel flow into the the IP - enigine runs out of fuel and stops.
Old 11-04-2010, 08:51 PM
hooksetz's Avatar
Thank you lcam, and the fss is located in the ip right? My starter switch on the column busted in half mid drive and that was what caused my truck to keep going. So hopefully the fss is not an issue on my truck yet.
Old 11-05-2010, 12:47 PM
Yes indeed, the FSS lives inside the IP, under the top cover. Those switches are a know problem by the way, I've seen quite a few of them halfway split on customers vehicles - and there was a TSB on those to boot, cause they like overheating and causing fires when they get loose like that.
Wipers won't shut off Dalozsw Electrical Systems/Wiring 7 02-08-2015 07:19 AM
91 F250 Fuel Pump Harold Lee 1987 - 1996 F150 & Larger F-Series Trucks 3 07-07-2014 06:36 PM
91 f150 fuel pumps wont shut off Redneck86ford 1987 - 1996 F150 & Larger F-Series Trucks 1 10-01-2007 08:26 AM
Brake lights won't shut off utbroncogirl 1978 - 1996 Big Bronco 4 08-08-2007 12:16 AM
91 Aeorstar - Daytime Running Lights Won't go out vonJaerschky Aerostar 3 10-17-2003 09:05 PM
Tags
1990, 73, check, diesel, engine, f250, ford, fss, fuel, line, powerstroke, shut, solenoid, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
