'84 F-150 Blown Fuse? Headlights not working... - Ford Truck Enthusiasts Forums
Old 11-02-2010, 10:30 PM
maybelle'84 maybelle'84 is offline
maybelle'84 is starting off with a positive reputation.
My 1984 Ford F-150's headlights went out this morning. Pretty sure it's a blown fuse...no idea where the box is. Looked at some diagrams, can't figure it out. Anyone know? How about which fuse is the right one for headlights? Help is greatly appreciated!!! ))
Maybelle'84
Old 11-02-2010, 10:39 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The headlights are not fused. The only thing they have is a fusible link over at the pass fender under the hood.
The best thing to do is get a testlight or voltmeter, turn the headlights on, and probe the dimmer switch in the floor. If you have voltage on one of the wires at the dimmer, then the headlight switch is ok, and it might be the dimmer switch if you do not have voltage on any of the other two wires.
If you do not have any voltage on any of the wires at the dimmer switch, I would pull the dash and check the headlight switch itself.
Old 11-02-2010, 10:46 PM
Thank you so much!
Maybelle'84
Old 11-03-2010, 08:32 AM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
A funny thing happened to me once. I had a headlight go out in my truck, so I replaced it. Two days later, when I went to leave a friends (at 11pm), both of my headlights went out when I turned them on. After searching high and low for three days, I found the problem. Both headlights blew out at the same time. It was time for the old one to go out, and the new one was defective. I replaced them and have had no issues since. From now on I will always replace the headlights in pairs.
Old 11-04-2010, 07:58 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
The Headlamp switch is on a circut breaker. This will cause the lights to Flicker or flash on and off, but wont let the lamps go completely out when there is a short circut or defective headlamp switch.
The dimmer switch would be the first thing I would check as well. Wet feet and corrosion are very common cause of dimmer switch failure.
Headlights work but no other lights do? Help. Donkey punch 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-08-2014 09:50 PM
Headlight help RangerDude17 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 01-26-2014 04:30 PM
Headlight problem manlikesford 1987 - 1996 F150 & Larger F-Series Trucks 2 08-26-2013 08:20 PM
No dash lights, ideas? cadunkle 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 07-08-2013 09:46 PM
keep blowing courtesy lamp fuse guindian28 Electrical Systems/Wiring 19 01-20-2011 09:54 AM
Tags
1985, 1986, 72, 77, 84, f150, f250, ford, fuse, headlight, headlights, problems, stopped, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
