C6 lower planetary gearsets - Ford Truck Enthusiasts Forums
Old 11-02-2010, 04:52 PM
carlmaass carlmaass is offline
carlmaass is starting off with a positive reputation.
Anybody ever have any experience with installing lower planetary gears in a C6? 10% lower 1St gear and 5% lower 2nd gear. I would like to install these in my next rebuild but I'm not sure if they would offer me anything over stock.
My F350 4X4 has plans for a 460. Its got 33's on it and the diff gears are 3.55's?
I don't rock crawl, race through the mud, or tow a 5th wheel. It does however have the higher diff gears (they are NOT 4.11). My future plans (along with a built 460 w/head work) include a locker and a snow plow.
Thank you for the replies.
Old 11-03-2010, 09:10 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
I've never had a set but someone on here mentioned a while back if he had it to do over again he wouldn't have invested the money in them.
Old 11-03-2010, 10:51 AM
ford005's Avatar
ford005 ford005 is offline
ford005 is gaining momentum as a positive member of FTE.
I was wondering the same thing. I have a rebuilt 460 2wd E4OD (of no use to me) that, if I can't sell, I can get the gear set out of.
Old 11-03-2010, 03:23 PM
The E4OD is where the lower gear planetaries come from? I might be able to score a core for pretty cheap if it will have all the parts I need to stuff into a C6.
The complete kit from PATC costs a bit more than what I would like to spend.
Old 11-03-2010, 05:02 PM
ford005's Avatar
From the little research I did on them, I think they do. Not sure exactly what all you can use out of the E4OD and what else you may have to find to get it all to work.
E4OD Upgrade question ng19delta 1987 - 1996 F150 & Larger F-Series Trucks 18 11-24-2016 10:19 AM
Word to the wise, backing with 5th wheel attached olfordsnstone Fifth Wheel & Gooseneck RV Towing 9 03-20-2016 07:01 AM
Another diff ratio question. tiger100 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 08-15-2015 07:48 AM
Questions on changing to E4OD planetary set in a C6 compressorguy Clutch, Transmission, Differential, Axle & Transfer Case 6 01-02-2009 12:43 PM
Low ratio gear set (planetary) for C6 TRADITION FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 02-12-2008 02:42 PM
Tags
c6, ford, gear, gears, low, lower, performance, planatary, planeary, planetairy, planetaries, planetary, swap, truck, update
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
