Fuel Sending Unit Problems on my F-350 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-02-2010, 05:35 PM
pbgsho2 pbgsho2 is offline
pbgsho2 is starting off with a positive reputation.
When I switch to my front tank the fuel gauge needle swings wildly from full to empty. The truck runs normally. On the rear tank the gauge displays the correct level of fuel so one must assume the problem is the sending unit in the front tank.
Does anyone have any suggestions of where I should begin to look for the problem.
Thanks,
pbgsho2
Old 11-02-2010, 05:51 PM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
I believe that most of the factory front tanks have a brass float. They develop holes or cracks that can allow fuel to enter thus compromising its ability to float. Full of fuel it is now pretty much buoyant or even weighted and will most likely go wherever the motion of the fuel takes it(up or down). Seems like yours may have chosen down...
Old 11-02-2010, 06:34 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
I would take a look at the ground wire from the sensor
Old 11-02-2010, 06:39 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
My truck was doing that on one tank a couple years ago too. I was going to look at the ground when I got a chance and could find it, didn't know where it was, then it quit doing it, fixed itself I guess.
Old 11-02-2010, 06:54 PM
JamesHajek's Avatar
JamesHajek JamesHajek is offline
JamesHajek is gaining momentum as a positive member of FTE.JamesHajek is gaining momentum as a positive member of FTE.
Mine does the same thing....
Old 11-02-2010, 07:26 PM
redman84's Avatar
Quote:
And I'd listen to Rick...
Old 11-26-2010, 10:58 PM
This is an update to my fuel sending problem. Several days ago while driving to Walmart, I switched to the tank with the fuel sending problem. It began to buck and run really rough. Switching back to the rear tank it smoothed out and ran normally. While getting fuel I decided to put some in the front tank knowing that this would complicate dropping the tank to replace the sending unit. After leaving the station I switched to the front tank and was surprised to find the engine running normally and that the gauge was stable and appeared to read the correct amount of fuel.
The only possible explanation is that the tank was really out of fuel with the float at it's lowest position that caused the strange reading. When I originally posted I incorrectly stated the gauge was pegged on empty when it was actually reading full. Go figure.
To the respondents who stated the gauge fixed itself, was your tank really empty and with the addition of fuel did it began working? I don't like things to fix themselves but in this case I will accept it.
I did check the ground wire and found it attached and properly grounded.
pbgsho2
Old 11-26-2010, 11:51 PM
bad12jr's Avatar
bad12jr bad12jr is offline
bad12jr is gaining momentum as a positive member of FTE.bad12jr is gaining momentum as a positive member of FTE.
Could had some crude stuck on the sending unit.
Old 11-27-2010, 07:45 AM
Mine wasn't empty, when I'd fill it it would go all the way up, bounce back down to half or so, and just kinda do that some. Like I said, I did nothing to fix it, been about a year or so now with no more issues???
Old 11-27-2010, 08:33 AM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Fullcrew7.3 has a good reputation on FTE.Fullcrew7.3 has a good reputation on FTE.
My front tank started doing this about 2 weeks ago. Haven't had a chance to look at it, but I'm going with the ground wire as it jumped up a few times and settled slowly back to MT. That's with a full or MT tank.
Glow Plug Relay Location on 2011 Superduty pbgsho2 1999 to 2016 Super Duty 1 05-15-2012 05:40 AM
Brake Problem with 97 F-350 pbgsho2 1994.5 - 1997 7.3L Power Stroke Diesel 10 01-20-2012 06:50 AM
After sitting the truck has no acceleration pbgsho2 1994.5 - 1997 7.3L Power Stroke Diesel 2 04-07-2011 04:02 PM
Front Pump Seal for E4OD Tranny pbgsho2 1994.5 - 1997 7.3L Power Stroke Diesel 7 07-16-2010 12:06 PM
Retrofitting an OBS with the Crankup Spare Tire Parts pbgsho2 1994.5 - 1997 7.3L Power Stroke Diesel 2 05-08-2010 08:17 PM
Tags
1996, 2006, 350, 73, 96, f250, f350, ford, fuel, ground, guage, issues, located, powerstroke, problem, problems, sending, unit, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
