Dash Trim Question and Pic request
I was wondering if anyone knew where I could get this lower dash trim (circled in red) and what it's called.
Also could someone post a side-view and head on pic of their ashtray opened with something for scale comparison (a dollar bill, etc.) I'm wanting to install a few 110V outlets in my truck and if it will fit in an ashtray I'll try to get one off ebay or junkyard.
I have one like this
Thanks for your help,
rhodester
rhodester
First one is a link to Ed's profile and the second is to his site. He should be able to hook you up with whatever you need. Send him a PM.
https://www.ford-trucks.com/forums/member.php?u=406391
Th!nk Parts Guy/FTE Parts Guy
You could also go with the F650 dash panel and customize it any way you wish. http://www.trademotion.com/partlocat...egoryID=145644
Can't help with a pic, mine is the same as yours.
That looks like the switch for an adjustable go pedal. Makes it slide forward or back.
Ahhhh nice!!! Any where in particular to get or order this lower dash panel? And the upfitter switch panel? And i assume its a direct bolt on ( the dash piece i am referring to)
Just looked at that pic. That a pretty badass setup as well. I know where to get the panel...but where do you get the switchs/panel i see in the pic? Can they be bought as a ford part or is that custom? Just need to decide which is more cost effective and easier.
TO THE O.P.
the 650 dash panel comes with a big hole where I mounted my switches, I did not make that clear in my first post. You could easily mount a couple of 110 plugs in there.
Here is a pic of the panel with the hole as it comes from FOMOCO
Lower Dash
hey guys im brand new to this site, i was planning on installing a bull bar with fog lights and i didnt want to drill into my dash or anything so i figured id look into the 05 upfitter switches. i have a 04, i was also curious as to how much it would potentialy cost, how much modification, etc. id also like the one with the driver side glovebox if its any help. any info would be great.
rhodester
04-07-2014 10:46 AM
skrappy
29
07-12-2013 01:43 PM
dadgonebroke
06-08-2013 08:29 AM
rhodester
09-11-2009 07:56 AM
