Coolant coming from radiator reservoir cap
1998 4.6L 106,000 Miles.
Engine overheated in August, water gushing from reservoir cap, tried flushing and refilling, same problem ocurred. Mechanic replaced water pump and thermostat, all seemed fine, then overheated again. Detected gas in the coolant so replaced radiator and head gaskets. New gasket set, bolts, heads skimmed and tested all replaced. (£1800!)
Have done 30-40 miles in truck, temp is good but have noticed a trickle of water from cap again! Any suggestions?
Johnny88Bronco
24
07-03-2007 10:55 AM
kneptune
07-27-2003 08:29 AM
