Truck won't start after changing glow plugs
Sundaytried starting truck 6-7 times and it fired 2 or 3 times but wold not start. SO i decided to change glow plugs which needed done for a while. Got drivers side done everything looked good there so i put new plugs in and put that side back together. went to passenger side pulled valve cover off and had 2 burnt wires. So I changed gasket and both uvc harness's and fixed plugs on outside of valve cover. Gpr was bad also so put new one on from napa gpr 109. Put it all together tonite went to start it and it just crankes over but no start, and tack moves when cranking it over. Any help would be great Thank you.
I'm currently experiencing the same issue truck ran when i parked it. I changed the drivers side glow plugs and when I went to start it it tried to start and then nothing now I have fuel at the bowl oil in the hpop and no smoke I'm stuck now
twistedcherokee
12-06-2014 02:19 AM
