Go Back   Ford Truck Enthusiasts Forums > Misc. > Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
  #1 (permalink)
Old 11-01-2010, 08:16 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
Garage is empty, add now
LARIAT 85 has a great reputation on FTE.LARIAT 85 has a great reputation on FTE.LARIAT 85 has a great reputation on FTE.LARIAT 85 has a great reputation on FTE.LARIAT 85 has a great reputation on FTE.
Considering Line-X: Over the Rail or Bedrail Caps?
I have made up my mind to get a Line-X in my 1985 Ford F150.
If I go with the Line-X over the rail, how neat does it look? Do the edges look good? I am trying to decide if I should do that or go with the replaceable bedrail caps.
What do you think?
One more thing. Are the bed bolts typically removed before the Line-X is applied? If not, what happens if I have to remove the bed? I am going to painting my truck soon, and the bed will have to be removed.
__________________
1985 Ford F150 XLT Lariat
*302: 0.060 over, CompCams 31-230-3, "Thumper" E7 heads, Edelbrock Performer intake, Autolite 4100-4V, Duraspark II, Thorley Tri-Y headers, Flowmaster 40 true duals
*AOD transmission
*2wd, 3.55 gears
Quote:
Life is too short to have anything but delusional notions about yourself!
  #2 (permalink)
Old 11-02-2010, 09:38 PM
12engine's Avatar
12engine 12engine is offline
12engine has a great reputation on FTE.12engine has a great reputation on FTE.12engine has a great reputation on FTE.12engine has a great reputation on FTE.
i have it over the rails on my 94 F150, and i like it. the lines are nice and straight, looks great.
In regards to the bed bolts, I dont know, I doubt they remove em though.
__________________
Brian L.ask for facebook 230,000+miles
1994 F150 XL 2wd standard cab short bed 300 I6
E4OD trans 8.8 rear towing package with 3/4 ton springs linex bedliner safety rack cab guard
  #3 (permalink)
Old 11-03-2010, 08:41 AM
TruckDaddy TruckDaddy is offline
TruckDaddy is starting off with a positive reputation.
You should discuss the application process with your dealer. You and the dealer should both have an understanding of the application.
That being said, typically, the bed bolts (and tie downs) are removed. However, if you want the bolts sprayed over, that's your option.
The over the rails process utilizes a tape with a wire in it. It creates a perfect LINE-X edge.
  #4 (permalink)
Old 03-09-2011, 06:54 PM
ns870 ns870 is offline
ns870 is starting off with a positive reputation.
This is probably too late for Lariat85, but for anyone else asking the question, I highly recommend over the rail. I got under the rail when I bought my 2004 ranger; the dealer told me it would look better. A couple years later I went back and had the rails sprayed. They were kind enough to charge me less than the cost of a new install, although it would have been free if I had done it that way the first time. If you plan to use your truck bed to haul stuff (what a concept!) you might as well protect the whole thing.
Tags
2011, arkansas, bed, cap, caps, duty, f150, ford, line, linex, rail, rails, removed, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
