Ford F250 Trailer Brake Controller - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-01-2010, 09:00 PM
robhavens robhavens is offline
robhavens is starting off with a positive reputation.
I couldn't find this specific topic so here goes.
Ford F250 SD 2005 crew cab FX4 lariat. bought used. Trailer brake controller comes on when i bump the dash, hit a good bump or touch the lever on the front and shows trailer disconnected error. I had Ford Dealer look at it and they said that it seemed to be a loose connection and they cleaned all connections in back of controller and tightened everything. Seemed to work for a week or so. slowly the problem is cropping back in. I haven't towed a trailer yet, so it can't be the wiring. I have seen where there have been other people with problems with this message, but they all relate to the trailer. A new controller OEM is 340. Screw that. Any suggestions?
Rob Havens
2005 Ford F250 FX4 Lariat Crew Cab
6.0 Diesel
Trailer "Disconnected" problem jonrjen Electrical Systems/Wiring 4 02-17-2015 04:55 PM
Possible Electric Brake Controller Issue? Ericwlod 6.7L Power Stroke Diesel 28 08-13-2014 11:45 PM
Productivity Screen Jupiter3102 1999 to 2016 Super Duty 15 04-19-2014 09:34 AM
1997 F-250 HD Trailer Brake connector location? bigsbetter11 1987 - 1996 F150 & Larger F-Series Trucks 3 05-22-2013 08:04 AM
towing capacity ford f-250 diesel fx 4 frenchsylvain 6.0L Power Stroke Diesel 2 06-19-2011 08:41 PM
Tags
1996, 2005, 2006, 2010, brake, controller, dash, diesel, disconnected, f250, f550, ford, fords, oem, problems, system, trailer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
