shaking truck - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
shaking truck
Old 11-01-2010, 05:40 PM
mauro12 mauro12 is offline
mauro12 is starting off with a positive reputation.
shaking truck
I have a 99 F250 7.3 diesel and when the truck is under light load (ie. driving 80km/h criusing when I start up a hill and need that extra bit of power the truck shakes like crazy unless I floor it). Does anyone have any suggestions?
Thanks Mike
Old 11-01-2010, 07:29 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
Would suggest you have your fault codes read.. might give you a clue on whats going on..
Old 11-01-2010, 08:16 PM
I have had it checked and nothing that would cause that came up all their was, was air intake heater, air bag, something to do with the radio and glow plugs. It has me stumped and I refuse to pay 100 bucks per hour shop rate to get it looked at as I can't afford that lol.
Old 11-01-2010, 09:04 PM
kupaa's Avatar
kupaa kupaa is offline
kupaa is gaining momentum as a positive member of FTE.
Does it always vibrate or shake when you are moving os just when you give it some gas?
Old 11-01-2010, 10:25 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Quote:
Thanks Mike
I had the same symptoms with one bad injector. No SES light, idled fine but would vibrate when trying to accelerate from 45-60 mph in top gear.
How many miles do you have on your engine? Stock injectors?
Old 11-02-2010, 05:07 AM
196,000 and as far as I know yes
Old 11-02-2010, 03:22 PM
Is their any way to diagnos this issue or just buying them and replacing them?
Old 11-02-2010, 03:24 PM
^KUPAA^
It is only shaking when on the gas if I just coast that that speed it is fine
Old 11-02-2010, 03:41 PM
Yes. If you have access to a scan tool such as Auto Enginuity, you can run some injector tests and also rule out some stuff. Everybody with a high mileage PSD should get this software because it pays for itself pretty quickly.
Riffraff Diesel: Total Ford Enhanced Bundle
Short of that, you can try a few other things. First of all, confirm your oil level is correct. Low oil can cause all kinds of weird symptoms. I then recommend you check your wiring harness. The main IDM connector has some dielectric grease from the factory and after 10 years it dries out and becomes flaky. Clean it with some electronics parts cleaner and apply new dielectric grease and do the same with the body to engine harness connector (Driver's side, below your IC and intake tubes). Also make sure your connectors at the valve cover harnesses are clean as well.
If that doesn't help anything, then your next step might be to look under the valve covers themselves. The under cover harnesses come loose all the time so you want to look at that first. Should be a nice tight fit. If you haven't done so already, install the Ford plastic clips to keep the harness from coming loose or perform the 50 cent mod. Do a search and you will find more info.
Then, while you have the valve covers off, start the engine and look at the oil discharge for each injector. You may find one or more injectors with abnormal discharge (too little or too constant). Both are bad.
You might also have a bad solenoid but that usually throws an SES light on your dash.
Good luck!
Old 11-02-2010, 04:04 PM
Ok thats awesome thanks Ill start looking at stuff this weekend when I get some time to do so. Your information is very helpful and appreciated
Old 11-06-2010, 07:19 PM
So I finally had the time to pull my truck apart and the 50 cent fix worked awesome. Thanks to everyone who gave me the advise. It was the best 50 cents that I spent (as well as the 170.00 for glow plugs lol) A big thanks to everyone who helped.
Old 11-06-2010, 07:43 PM
Great news.. !! Mine came apart at 70K.. and did the 50 cent fix.. been good ever since..Thx for reporting back ..
Tags
73, 99, dissel, early, ford, hill, powerstroke, shake, shaking, starting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
