Fuel, Oil & Tach Gauges Blowing Fuses
I start by looking right behind the fuse box, make sure none of the wires are bare/burnt.
Basically you'll need to follow the RED-YEL wire from fuse #18, from the fuse box to the instrument panel until you locate the short. It also supplies the warning chime module and low vac warning sw.
