What are the 5 best mileage improvements for 460 - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 01-06-2014, 11:12 PM
flaboy1979 flaboy1979 is offline
flaboy1979 is starting off with a positive reputation.
Only way I found is not drive the gas guzzling beast
  #62
Old 08-01-2016, 02:29 PM
bulldog 123 bulldog 123 is offline
bulldog 123 is starting off with a positive reputation.
I had a gm 454 one ton , well put me in the poor house,
now run Ford one ton 460
  #63
Old 08-01-2016, 08:34 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
poverty; it's a vicious cycle.
  #64
Old 08-02-2016, 07:12 PM
Phil Woolfson's Avatar
Phil Woolfson Phil Woolfson is offline
Phil Woolfson is starting off with a positive reputation.
Quote:
Originally Posted by Old93junk View Post
A F-250/350 with a 460 is not a daily driver............Its a piece of heavy equipment. Do not expect to make the mpg bearable for such duty, its just not going to happen.
Consider a Kia to drive when you don't need the truck.
The only thing I have found that helped even very slightly was going to long tube headers, took me from 11.5 to 12.5.........that is after I quit exploring the new found performance bump.
Umm, yes, it is.
  #65
Old 08-02-2016, 07:17 PM
I put in a throttle body spacer, did a shorty exhaust, keep well tuned, have replaced a lot of 27 year old sensors, injectors, dizzy, cap, wires proper copper plugs. Regular additives, seafoam, throttle cleaning, oil and gear case changes and run 93 oct.Tires 75# / 65#. Mileage typical between 12(stop&go) - 14 longer trips. I have a cab height cap, which helps.
gain hp + improve MPG evil-90 Performance & General Engine Building 17 09-03-2015 08:26 PM
Gas mileage 1986, F- 250, 460 , 4x4 datsun147 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 04-25-2011 01:41 PM
97 F-250HD 460 ignition Zebich Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 04-26-2004 01:29 PM
1996 F150 302 4x2 gas mileage BT820 1987 - 1996 F150 & Larger F-Series Trucks 2 01-16-2004 08:09 PM
Improving Mpg... Gas And Diesel? skychaney Aftermarket Products 8 06-15-2003 11:36 PM
Tags
460, big, block, cam, eeciv, engine, ford, improve, kurt, management, milage, mileage, mpg, set, zortman
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
