Signaling O2 sensor wire color code.. - Ford Truck Enthusiasts Forums
Old 11-01-2010, 03:58 PM
timbersteel's Avatar
timbersteel timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
I have a really good question for all the Ford folks. What is the Wire color for the Upstream O2 sensor that is located on the passenger side exhaust manifold? I have the Mitchell diagrams in my Haynes manual and I also have the '92 Powertrain/Emissions manual and I cannot find anything corresponding to that sensor or what wire color it would use.
When I got the truck, the weather pack connector was completey destroyed. I re-wired it, but I must be wrong. I traced the wires back, and the color wires I have are YEL-RED and GREY-RED. Those 2 wires correspond to a knock sensor, which I could not find a connector from a actual sensor working from the block. there was a 6-pointed piece in the block but it is flush with the sides.
I'm at a lost on my code 41, but my assumption about having the signaling O2 sensor not working correctly leads me in this direction.
Old 11-01-2010, 05:25 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
92 302 02 sensor
GRY-LT = HEGO BLU PCM pin 29
ORG = HEGO GND PCM pin 49
BLACK = Ground "E"
PPL-ORG = Fuse E eng compt f/b
YEL-RED and GREY-RED are Knock sensor conductors.
Your 92 would/should throw 3 digit codes no 2 so you miss counted or something is amiss there.
Old 11-02-2010, 04:24 PM
Thanks Danr1!
I was actually referring to the Signaling O2 sensor found in the pass. side exhaust manifold. It just has 1 wire.
I used the wire color for the HEGO sesnor to locate the bad ground running in the wire loom to the vehicle harness connector for the HEGO sensor.
The production date for my Blue '92 is 11/91 for my F-150, so it has only 2 digit codes from my Equus code reader. My Red '92 is 04/92 and it has 3 digit codes.
Driver side O2 sensor trouble 87diesel6.9 Excursion - King of SUVs 1 01-07-2017 10:36 PM
2000 Expedition O2 sensor issues, stumped... Andyjman Modular V8 (4.6L, 5.4L) 5 01-28-2016 07:27 AM
Is the second ECT sensor on 99-03' 7.3L mythical or does it exist? corksil 1999 - 2003 7.3L Power Stroke Diesel 48 01-17-2016 02:02 PM
Success story, Check Engine Light, P2197 F150Terry 2009 - 2014 F150 12 01-15-2013 06:10 PM
2007 wiring diagram fp_5 Ranger & B-Series 4 10-28-2012 11:14 AM
Tags
02, 29, 41, 460, code, codes, color, f150, ford, motor, o2, sensor, sensores, signal, truck, upstream, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
