7.3L "Cruise" RPM
7.3L "Cruise" RPM
Last week I posted that I have acquired a 1989 F-Super Duty with the 7.3L, 5 speed and Dana 5.13 rear end. I intend to transplant this drivetrain into my 1958 F600.
What RPM does the 7.3 like to turn when cruising down the highway at 60-70 mph with no load on the truck? In it's current configuration the engine turns 2600 RPM at 60 mph. Would 1800-2000 RPM at 60 mph be too low as in "lugging" the engine?
If this rear axle is a Dana 80 I see that there are 4.10, 4.63 and 4.88 gears available. I will be running 9R-22.5 tires.
I'm wondering what the lowest RPM the 7.3 will be happiest with for fuel mileage purposes.
The following users liked this post:
Received 3,106 Likes
on
Hmmmm, mine runs 2500 rpm at 60 and 2750 rpm at 65 no load. It's an 88 F250 7.3 with an automatic. I got the truck a few months ago and the kid I got it from said it has a shift kit (it definitely shifts solidly). Not trying to hijack the thread but now I am wondering if mine is not right. I got it for pulling a heavy 30ft 5th wheel.
on
ROLLBACK F550 cruising rpm
on
ive got 2 1999 7.3L diesel. Both tow trucks. 450 and 550 both manual. But my cruising rpm at 55 mph is about 2000 rpm in 5th gear so from what I’m reading your truck sounds like it’s where it should be. I got on here wanting to know if I’m lagging or rapping the truck out at 60 doing 2300 rpm. I keep it between 55-58 I get 13mpg. After reading what I’ve read I’d say you might have a shift kit in there an electronic chip most likely but sounds like it’s where it should be. All kinds of stuff to change that but if it ain’t broke don’t fix it lol
out trucks are old school, no computers, no electronics of any kind. all we need is 12 volts to the fuel shut off switch and they will run forever.
your trucks are totally computer controlled.
