Overdrive button - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Overdrive button
Old 11-01-2010, 10:25 AM
jwaz_2000 jwaz_2000 is offline
jwaz_2000 is starting off with a positive reputation.
Overdrive button
I have a 2002 F-350 7.3 Diesel 4x4 Extended Cab LB. I can only use the Overdrive button if the truck is in park. I can turn overdrive off and on in park only. If I press OD button while in Drive nothing happens. Is there something wrong? Thanks in advance
Old 11-01-2010, 10:45 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
It would help a lot if you'd post the year and model vehicle you are talking about!
Old 11-01-2010, 10:51 AM
GIGGER's Avatar
GIGGER GIGGER is online now
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
do you mean "Tow Haul" probably a broken wire or short in the steering column
Old 11-01-2010, 11:17 AM
Spool&Go's Avatar
Spool&Go Spool&Go is offline
Spool&Go has a very good reputation on FTE.Spool&Go has a very good reputation on FTE.Spool&Go has a very good reputation on FTE.
I have a similar issue. I have done quite a bit of research on it. Basically, the reason that it works when you are in park is because of a short. The wires that run from the button, go over the steering column. After years of shifting with the handle, the wires (or wire) rub raw. When you are in drive the wires lay flat because they are extended, and they short out. When you are in park, there is enough slack in the wires to keep them off of anything. That is why it works at that point in time.
At first mine was just iffy. It would sometimes work and sometimes not work. I bet if I try pressing it while in park I will have the same thing going on. Basically you need to get in there, find the short and fix it. I need to do this same thing. I will try to find the link that I was reading on what to do.
Hope this helps
Old 11-01-2010, 12:52 PM
89CrewCab 89CrewCab is offline
89CrewCab is starting off with a positive reputation.
It is a short. My transmission guy says this is common problem and he merely replaces the entire shifter lever. He does so many, he keeps them in stock. He charged $80 for parts and labor.
Old 11-02-2010, 02:58 AM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
Here is a post with pictures so you can see the shorted area and fix it. http://www.ford-trucks.com/forums/74...uestion-3.html
Old 11-02-2010, 10:11 AM
Spool&Go's Avatar
Thanks for the link. Hey can anybody save those pictures to their computer and send them to me via email? I have a pretty intense filter on this comp and it will not display the pictures. Dont wan't to mess with my computer settings either. Let me know and I will PM you my email address. Thanks
E4od overdrive switch ? garagegods 1987 - 1996 F150 & Larger F-Series Trucks 4 07-05-2015 09:16 PM
OVERDRIVE BUTTON QUESTION NBT22555 1999 - 2003 7.3L Power Stroke Diesel 9 06-25-2014 02:32 PM
Overdrive button on gear shift amyr61 1999 to 2016 Super Duty 2 08-07-2011 06:32 PM
Q's about operating an overdrive unit DarrellJ 1967 - 1972 F-100 & Larger F-Series Trucks 6 10-30-2010 05:45 PM
overdrive button not working [96 f150] jimbo beam 1987 - 1996 F150 & Larger F-Series Trucks 5 10-14-2006 10:09 AM
Tags
01, 2002, 2009, 73, button, diesel, escape, f150, f350, ford, overdrive, superduty, truck, trucks, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
