1997 4 cyl Ranger died and won't start - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-31-2010, 09:14 PM
mskeen mskeen is offline
mskeen is starting off with a positive reputation.
My friend's 1997 4 cyl ranger died and won't start. Cranks fine with no codes on OBD2. Was running fine before it died. Any ideas"? Thanks, Mark
Old 10-31-2010, 10:31 PM
97ranger xlt's Avatar
97ranger xlt 97ranger xlt is offline
97ranger xlt is starting off with a positive reputation.
1st thing to check is if the timing belt snapped...
Old 10-31-2010, 11:48 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Will it start with starting Fluid?
If so then look to fuel issues.
If not then it might still be fuel issues, but look to spark/timing issues.
Old 03-27-2012, 02:01 AM
steelsail steelsail is offline
steelsail is starting off with a positive reputation.
Mine just did the same thing. I like the first suggestion. Doesn't hurt to have someone crank it over while I look through the oil fill cap and see if the rocker arms are moving.
My truck flat died on the highway, still there, and now my buddy is gonna try and help me figure out what's going on. I hope its a fuel issue, since I almost ran out of gas and then filled up, before this happened. But I will check my timing belt first, thanks for the good advise (would've never thought to check the belt first).
Ray
Old 07-08-2014, 11:43 PM
drb1956 drb1956 is offline
drb1956 is starting off with a positive reputation.
dead ranger
Its funny, that the maintenance schedule doesn't even mention the timing belt until 120,000, and then its just an inspection. Whats up with that -I know those belts are durable, but I think 100K is enough life expectancy. After that its going to leave you somewhere when you least expect it. And then there's the variables of how the truck is used, or abused if the shoe fits, weather and the likes of stop and go(abuse). Oh yeah, before I forget- BUY A GOOD BRAND AND DON"T BE A CHEAPSKATE WITH THIS PART-IT WILL COME BACK AND BITE YOU, YOU KNOW WHERE!! And while you're in there, change the water pump (I know most are external), but its a good time as any while you're bent over the grill of your favorite ride..
Old 07-10-2014, 11:43 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Most times, the belt won't snap, but will get out of time when some of the teeth break loose and allow the belt to slip. The way to check is to put the crankshaft at TDC, and then check the cam sprocket triangle being at the pointer behind the plastic plug in the front cover. You might have to rotate the crankshaft another 360 if the triangle is not aligned, but it should align once for every two crankshaft rotations.
Most times again, they also break when you go to start the engine. I guess trying to overcome the load of the valve springs at slow speeds can tear the teeth loose.
If you stop running going down the highway, I'd be more inclined to check fuel pump output and pressure first. Then follow with ignition and cam / belt checking.
tom
my 87' ranger v6 2.9 dies in reverse. Carl Tritch 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 0 08-27-2016 07:39 AM
Tank switch/injector/ignition? problem Lane Locke 1987 - 1996 F150 & Larger F-Series Trucks 1 08-02-2016 06:28 PM
'14 6 cyl 150 won't start-ideas? tim nick 2009 - 2014 F150 0 02-24-2016 08:02 PM
88 ford ranger 4x4 stalling cutting out sputtering Hippen Ranger & B-Series 1 02-11-2014 01:03 AM
1998 4cyl died on the highway big79bronco Ranger & B-Series 15 03-16-2011 01:09 PM
Tags
1997, 23l, 4cly, 4cyl, 92, 97, crank, cyl, cylinder, cyn, died, ford, ranger, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
