axle code c7x
Old 10-31-2010, 05:36 PM
78_f150's Avatar
78_f150
78_f150 is offline
axle code c7x
I am trying to source a dana 60 or dana 70 rear axle with a 4.10 or 4.11 axle ratio.
I have 2 trucks, 1 is a 79 2wd crew cab short bed. it has an axle code of c7x.
the other truck is a 77 2wd long bed, camper special truck. all factory with a 390 in it. not sure of axle tag on this one.
what is my best bet to find a dana 60 with a 4.10 or 4.11 ratio.
Old 10-31-2010, 05:39 PM
steponit's Avatar
steponit
steponit is offline
Axle C7 - Dana 60 L/S 3:54 5300lbs
X means you have a tilt steering column or as ford call is an Adjustable Steering Column
axle B4 is what you are looking for Dana 60 ,4:10
or D7 -Dana 70 L/S 4:10
Old 10-31-2010, 05:44 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C7X: C7 = Dana 60 / 3.54-1 / LIMITED SLIP / 5,300 lb. Rear Axle Capacity.
X = Tilt wheel? X isn't listed in any of my parts catalogs....for anything.
There are EIGHT different codes for a tilt wheel, none are X.
If the AXLE code begins with a letter = Limited Slip. With a number, no Limited Slip.
Old 10-31-2010, 09:08 PM
supercabfreak's Avatar
supercabfreak
supercabfreak is offline
what does a 27J decode to be in a 76 f350?
Old 10-31-2010, 09:45 PM
steponit's Avatar
steponit
steponit is offline
J always means power steering
Old 11-01-2010, 01:38 AM
axbreck's Avatar
axbreck
axbreck is offline
AMC 20 rear end
I have just bought a 1975 F100, the problem is the ford 9 inch rear end is gone, but there is an Jeep AMC 20 CJ6 rear axle bolted to the leaf springs, but this axle is not wide enough it measures 58.5 inchs WMS to WMS but i think it needs to be approx 4 inches wider.
Can I make up the difference using 1.5 inch wheel spacers and wider offset rims or should I try and source a wider axle.
I'm in the UK and ford 9 inch axles are rare, most on the back of drag cars.
Thanks in advance
38 coupe
20
03-01-2023 08:43 AM
Radster
12-05-2016 01:20 PM
jmadsen
08-06-2014 05:42 PM
mjdaye
05-31-2014 04:49 PM
Gertie-The '49 F2
20
07-28-2012 05:55 PM
Quick Reply: axle code c7x
