payload and towing of a Ford F-450 pickup vs. truck with comparable engine - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-31-2010, 05:03 PM
George R George R is offline
George R is starting off with a positive reputation.
While it costs around 3x, the specifications of an Mercedes-Benz Atego 1725A truck with 6.4 turbo diesel with approximately 250 hp and 660 ft-lbs (6 cylinder OM-906LA) are: truck bed and payload capacity of ~26.000 lb plus conventional towing capacity of ~40.000 lbs. That capacities should be similar to an US spec Unimog U 500.
Ford has a payload capacity of ~5000 lbs and can tow conventionally 16000 lbs, or 24.500 lbs with fifth wheel.
The payload would be related to axles with more capacity, however since the F-450 has bigger engine (6.7 Ford V8 with 400 hp and 800 ft-lbs) why it also has lower towing capacity?
How much lower is the consumption of the F-450 compared to a truck while towing the same 24000 lbs?
Thanks in advance for any related comments.
Old 10-31-2010, 07:04 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Just from looking at the pictures since the Merc is a cabover that would allow a lot more GVWR. I am also guessing it has a larger frame larger axles and larger brakes as well as larger tires. F450's only have 19.5 rims. Towing capacity takes all things into account, braking, frame strength, wheel rating, axle rating, transmission etc etc.
From the looks of that Merc it would be far more comparable to a F650 or F750.
Old 10-31-2010, 07:32 PM
tgreening's Avatar
tgreening tgreening is offline
tgreening has a good reputation on FTE.tgreening has a good reputation on FTE.
Another consideration that Ford takes into consideration is registration and licensing requirements. When capacities go up drivers license requirements get more complicated, and putting plates on the back of the thing gets more expensive, along with insurance etc etc. Plates for my 450 cost $250 for 1 yr.
Ford rates the axle in the back of my truck at 9500# Part of that I'm sure is because of the tires they put on it, but also with all of the above in mind. The axle manufacturer otoh rates the axle at 14,500#.
The truck you are talking about is in a whole other class and makes no bones about the market it is intended for.
Old 10-31-2010, 07:43 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
The Mercedes requires a CDL for most situations. The F-450 does not.
Anomic Anomic is offline
Anomic is starting off with a positive reputation.
Also the 6.7 is way overpowered for a 26k gross vehicle. Ive driven vehicles that are at (or a bit over!) 26k and have less than 300ftlb tq.
Payload Capacity - 2003 F550 - 16ft flatdeck Jas_d 1999 to 2016 Super Duty 1 02-04-2015 03:54 PM
F250 conventional towing discrepancy qflyer Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 26 01-17-2015 07:10 AM
Differences between F350 vrs F450 wo.ody 1999 to 2016 Super Duty 5 05-16-2014 03:05 AM
How much is to much? (Towing Capacity) 640 CI Aluminum FORD 2009 - 2014 F150 11 08-29-2010 11:37 AM
2002 F-250 7.3 L 5th wheel towing jlshannon 1999 - 2003 7.3L Power Stroke Diesel 10 02-12-2010 03:17 PM
Tags
1999, 2001, 450, capacity, cdl, comparable, f450, ford, payload, ratings, requires, tires, tow, towing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
