rear axle alignment
Old 10-31-2010, 12:35 PM
low 66's Avatar
low 66
low 66 is offline
rear axle alignment
Ok I think my rear axle is out of alignment how do I tell if it is and how do I correct it is their a way to measure to tell if it out of wack
Old 10-31-2010, 02:33 PM
Bill W's Avatar
Bill W
Bill W is offline
If you rear leaf spring bushings are shot it most likely is out of wack, a 4 wheel alignment will tell the tail. most shops offer a 4 wheel alignment service.
Old 10-31-2010, 03:14 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
If a rear spring leaf breaks, this causes the rear axle to shift over to one side. Dog tracking = what happens when the rear axle shifts over.
Have someone drive your truck, you follow several car lengths behind. If the axle has shifted over, you will see all four tires (dog tracking), not just the rears.
Old 10-31-2010, 05:09 PM
low 66's Avatar
low 66
low 66 is offline
The spring bushing are ok and springs are not broke but I did take a few more measurements and I believe who owned the truck before me didn't put the cab on exactly square so it was throwing my measurements out I checked it from some rivets that where placed equal on both sides and it measured out good
Old 10-31-2010, 06:31 PM
CropDusterMan's Avatar
CropDusterMan
CropDusterMan is offline
On the leafs, there are two bumps on the underside of the spring that match into the
mounts on the differential (I'm assuming its a Dana 60)...perhaps they are not aligned in the holes...?...
I doubt it could even go together though...
Old 10-31-2010, 06:40 PM
low 66's Avatar
low 66
low 66 is offline
Thanks crop duster man the springs and rear are original so I believe that can't be it
Old 10-31-2010, 07:03 PM
NumberDummy
How do you know? How long have you owned the truck? How long has this problem been occuring?
These trucks are over 40 years old and have had multiple owners (with a very few exceptions).
So, at some point in its life, it could have been in an accident, the frame coulda been bent. It was never fixed or parts were installed that could be incorrect, or were installed improperly.
Old 10-31-2010, 08:45 PM
oldblu's Avatar
oldblu
oldblu is offline
I would have to agree with BW. The only way to know is have it measured (alignment check) professionally.
Grape Nehi
02-19-2017 03:56 AM
green_95
12-02-2016 05:47 AM
granny_rocket
03-31-2016 01:33 PM
beartracks
New Mexico Chapter
10-14-2015 12:56 PM
v10kenj
2009 - 2014 F150
01-10-2014 10:10 AM
Quick Reply: rear axle alignment
