rear axle alignment - Ford Truck Enthusiasts Forums
rear axle alignment
Old 10-31-2010, 12:35 PM
low 66 low 66 is offline
low 66 is starting off with a positive reputation.
rear axle alignment
Ok I think my rear axle is out of alignment how do I tell if it is and how do I correct it is their a way to measure to tell if it out of wack
Old 10-31-2010, 02:33 PM
Bill W's Avatar
Bill W Bill W is offline
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
If you rear leaf spring bushings are shot it most likely is out of wack, a 4 wheel alignment will tell the tail. most shops offer a 4 wheel alignment service.
Old 10-31-2010, 03:14 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
If a rear spring leaf breaks, this causes the rear axle to shift over to one side. Dog tracking = what happens when the rear axle shifts over.
Have someone drive your truck, you follow several car lengths behind. If the axle has shifted over, you will see all four tires (dog tracking), not just the rears.
Old 10-31-2010, 05:09 PM
The spring bushing are ok and springs are not broke but I did take a few more measurements and I believe who owned the truck before me didn't put the cab on exactly square so it was throwing my measurements out I checked it from some rivets that where placed equal on both sides and it measured out good
Old 10-31-2010, 06:31 PM
CropDusterMan's Avatar
CropDusterMan CropDusterMan is offline
CropDusterMan is gaining momentum as a positive member of FTE.CropDusterMan is gaining momentum as a positive member of FTE.
On the leafs, there are two bumps on the underside of the spring that match into the
mounts on the differential (I'm assuming its a Dana 60)...perhaps they are not aligned in the holes...?...
I doubt it could even go together though...
Old 10-31-2010, 06:40 PM
Thanks crop duster man the springs and rear are original so I believe that can't be it
Old 10-31-2010, 07:03 PM
Quote:
How do you know? How long have you owned the truck? How long has this problem been occuring?
These trucks are over 40 years old and have had multiple owners (with a very few exceptions).
So, at some point in its life, it could have been in an accident, the frame coulda been bent. It was never fixed or parts were installed that could be incorrect, or were installed improperly.
Old 10-31-2010, 08:45 PM
oldblu oldblu is offline
oldblu is starting off with a positive reputation.
I would have to agree with BW. The only way to know is have it measured (alignment check) professionally.
Labor charges green_95 1994.5 - 1997 7.3L Power Stroke Diesel 9 12-02-2016 05:47 AM
4x4 front axl aligment shim granny_rocket 1987 - 1996 F150 & Larger F-Series Trucks 4 03-31-2016 01:33 PM
Rear Wheel Alignment v10kenj 2009 - 2014 F150 12 01-10-2014 10:10 AM
'01 Expedition Rear Axle Seal Trouble John Boyd 1997-2006 Expedition & Navigator 6 12-30-2012 12:10 PM
f600 rear axle not square with frame stock truck 1967 - 1972 F-100 & Larger F-Series Trucks 6 12-31-2004 01:53 PM
Tags
2011, 78, alianment, aligning, alignment, alinement, axel, axle, dog, end, f250, ford, problems, rear, tracking, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
