Miles on your ranger...list
Old 01-30-2016, 01:28 PM
ford 03's Avatar
ford 03
ford 03 is offline
207,500 on my 03 ranger with the 4.0
  #1457
Old 02-26-2016, 08:03 AM
nht00py's Avatar
nht00py
nht00py is offline
211,000 on my '96 with 2.3L. Bought it with 203K, did some minor maintenance to the motor(timing belt, water pump, plugs, wires, coils) and it runs like a top. Did some major maintenance to the outside(2001 front end, 2002 step side bed, re-painted ford Kodiak brown, 18's)
  #1458
Old 02-26-2016, 04:56 PM
David Nouchi's Avatar
David Nouchi
David Nouchi is offline
1998 ranger xlt v6 4.0L 4.0L. Just hit 140,000
  #1459
Old 03-02-2016, 10:13 PM
merkswitch's Avatar
merkswitch
merkswitch is offline
120k on mine, bought it with about 118.5k.
Work done so far in that time:
Oil change
Timing belt
Drive belt
Tensioner & idler pulleys
Spark plugs & wires
Valve cover gasket
PCV valve
5 new tires
Spare tire winch & rim
Right side parking brake cable
Repaired rear brake line
Repaired speedometer wiring (after replacing diff sensor...)
Fixed license plate lights
Front marker light bulbs
Buffed headlight lenses
Both front upper control arms
Exhaust, manifold-back
Wiper blades
Just took it on a 500 mile road trip and it ran perfectly, albeit a bit slow on the return since we were towing a trailer into a strong headwind.
  #1460
Old 03-26-2016, 05:18 PM
mpwbw's Avatar
mpwbw
mpwbw is offline
08' 3.0 Liter V6
Just hit 111,500 last week.
Basically, all original except AC Condenser or Compresser and heat accuator.
Solid vehicle, and more than happy.
  #1461
Old 03-27-2016, 07:35 AM
shultzaberger's Avatar
shultzaberger
shultzaberger is offline
My 2003 XL 2.3L just topped 130,455 last week. That's about 10,035 a year which is not too shabby.
  #1462
Old 03-28-2016, 11:24 PM
72GTS's Avatar
72GTS
72GTS is offline
2006 4X4 Fx4 4.0 5 spd. 132,000 miles no issues at all runs great. Pulls 20MPG hwy.
  #1463
Old 03-29-2016, 08:25 AM
john jamieson's Avatar
john jamieson
john jamieson is offline
'96 4.0 automatic is getting ready to turn 230,000.
  #1464
Old 04-01-2016, 04:32 PM
grunt98444's Avatar
grunt98444
grunt98444 is offline
2009 26,000 miles
  #1465
Old 04-01-2016, 09:45 PM
KeyzzDzz's Avatar
KeyzzDzz
KeyzzDzz is offline
I have a 1988 Ford Ranger 4 wheel dr I bought for $900 10 yrs ago. Today 3/30/16 I just spun off 400 k !!!!! I love this little truck. And with the REAL 4 wh she will walk up walls!
The week I bought this truck 10 years ago.
Today, 10 years later with a Rustoleum Paint job! ( I used a quart and a 3 inch Foam Brush!) The paint job here is already 8 months old and its wearing better than the factory Paint and Ive been in Key Largo for 5 years. Salt Air is rough on an old truck!
  #1466
Old 04-01-2016, 10:00 PM
KeyzzDzz's Avatar
KeyzzDzz
KeyzzDzz is offline
at 400,000 miles it Was TIME! In the past 3 months Ive had a lot of work done to it.... Now the clutch started to slip a year ago... and when the Water pump went out recently.. ( The FIRST time anything had gone down on her in 10 years..)... So,... I did all I could to it as far as Money goes
Water Pump
Muffler
New radiator
New thermostat
All New hoses & belts
New Clutch
New rear wheel cylinders & shoes
New Brake Booster
New Fuel Reservoir
All Freeze Plugs replaced
Valve Cover Gaskets
Tune up / Plugs - Wires
Oil change
The hardest one was this Fuel Reservoir under the driver side frame. I could not find one to replace the discontinued one from Ford that started to leak bad! Well that is until I found this site!!! I had been using 2 regular in-line fuel filters on the intake and return for a few short trips around town for about 3 weeks. It ran rough and got even worse if it got below a half of tank of gas.
Because of this site I was able to track one down!! Someone actually listed the replacement part number here. Once I had that it was easy!
THANK YOU "Ford Trucks.com !!!!" .... and your very informed members!
You guys saved Me & My Little Old Ranger!!
  #1467
Old 05-01-2016, 10:58 AM
rkmaxwel's Avatar
rkmaxwel
rkmaxwel is offline
2002 Ford Ranger - 2.3 - 2wd - Manual 5 spd.
Just rolled over 365,000 this past week. Bought used in 2005 with 50,105 miles on it. Daily driver with 500 miles a week put on it. Use synthetic oil. Do my own maintenance and repairs. Great truck. Love it!
  #1468
Old 05-02-2016, 02:19 AM
Supercab's Avatar
Supercab
Supercab is offline
My 2003 Ranger Edge 3.0 has 107k miles, runs well.
  #1469
Old 05-07-2016, 11:17 AM
97ranger xlt's Avatar
97ranger xlt
97ranger xlt is offline
2002 4.0 4x4... 83k on it now
  #1470
Old 05-09-2016, 05:32 PM
Thinlizzy13's Avatar
Thinlizzy13
Thinlizzy13 is offline
03 I4 5spd, just rolled over to 85k. Many miles left on it
Quick Reply: Miles on your ranger...list
