Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 10-31-2010, 10:47 AM
bfnavarrete bfnavarrete is offline
Garage is empty, add now
bfnavarrete is starting off with a positive reputation.
2004 6.0L oil pressure switch leaking
I have a 6.0L F-350 6.0L PSD with 265,000 miles. The truck started leaking/spilling oil between engine and bell housing on passenger side. i found the leak to be coming from the oil pressure switch so i replaced it. 1 day later, the truck started to drip and by the end of the day turned into a leak/spilling of oil. thinking that it could of been a faulty part, i replaced the switch again. again, 1 day later a small drip formed and quickly turned into a leak/spilling of oil. all gauges read fine and the oil pressure reads normal.
Have y'all had this problem before? could there be an intermittent problem causing the switch to fail?
Thanks in advance
  #2 (permalink)
Old 10-31-2010, 08:10 PM
anyone??? ttt
  #3 (permalink)
Old 11-05-2010, 09:12 PM
2001 bolt's Avatar
2001 bolt 2001 bolt is offline
2001 bolt is starting off with a positive reputation.
the reason the oil pressure switch keeps failing is due to oil contamination that is still in the connector end...make sure you clean all of the oil out of the connector and whipe it clean and make sure you dont spray any cleaner on the new sensor as they are pretty delicate and will just keep leaking...hope this helps
  #4 (permalink)
Old 11-05-2010, 09:29 PM
6litremachine 6litremachine is offline
6litremachine is starting off with a positive reputation.
replace the connector end too... rather than cleaning it, they're relatively easy, they are stocked by most ford dealers, and not too expensive. be sure to put the silver wire loom back on to protect from heat.
  #5 (permalink)
Old 11-05-2010, 09:39 PM
djanzen's Avatar
djanzen djanzen is offline
2003 Ford F-250
djanzen is gaining momentum as a positive member of FTE.djanzen is gaining momentum as a positive member of FTE.
Where is this switch? the pressure switch for the 6.0 is in the oil cooler at the front of the engine on top?
__________________
Dean
2003 CC/SB/4X4 6.0 LARIAT 3.5 leveling kit by fab tech, 08 taillights and bumper, bocar front bumper, 05harley headlights, egr delete by ME. Auber egt, trans,fuel pressure gauges.
2011 F550,vmac compressor,Tiger 5000lb Crane, 11.5 Brutus service Body http://www.ford-trucks.com/forums/11...ice-truck.html
Tags
2003, 2004, 60, 60l, drips, f350, ford, leaking, leaks, liter, motor, oil, passenger, pressure, side, switch, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
