2007 Explorer radiator install
Old 10-31-2010, 10:25 AM
stroker393's Avatar
stroker393
stroker393 is offline
Got 56000 miles on my '07 4.0 Eddie Bauer and have had a light leak from the radiator for about 4000 miles. Numerous complaints on the net about these radiators in 06-07 models. I'm posting this to give some insight on what I encountered doing the swap and what I found that made the project pretty simple. There are (2) bolts that hold the A/C condenser tight between the side supports for the radiator/condenser and if you loosen these it gives the supports the movement you need to pull the radiator out. If you look down over the radiator in front you will see them and this will make the difference in hours of doing this swap. When you're installing your new one remove the (4) fan shroud clips on the side supports to give ease in sliding the radiator down into the brackets. I took pics of everything and when I have the time I'd like to do a tech article for this installation.
Old 12-31-2010, 03:34 AM
azsixshooter's Avatar
azsixshooter
azsixshooter is offline
I'd be interested in a tech article on this. My '06 has a radiator leak and the guys at the garage said it is where the reservoir meets the radiator itself and that stopleak/barsleak doesn't work well for fixing leaks in that area. They quoted me something like $500 to replace the radiator. I should be able to get the part and do it myself at my uncle's place with his help. I didn't know this was a common issue with 06/07 Explorers. TIA.
Old 12-31-2010, 01:47 PM
texanranger's Avatar
texanranger
texanranger is offline
its a common problem with the plastic ford resevoirs. I have put 4 radiators in my 2006 F450 work truck.
Old 12-31-2010, 09:48 PM
impish's Avatar
impish
impish is offline
Sometimes these plastic "jobbies" just last forever, sometimes not. I have fortunately had very good luck with them so far, over 200k on the first Expl., 190k on second, now 110k on the third, and no radiator trouble.
But, I HATE the idea of a crimped-on tank!...........
Old 04-09-2013, 10:18 PM
bryan_h6121's Avatar
bryan_h6121
bryan_h6121 is offline
Maybe a dumb question, but what is the secret to changing the fittings for the tranny lines? advance auto parts sold me a small plastic "tool" for removing the old fittings and its not working, any suggestions on where i can find an online manual or web site detailing the replacement of the fittings would be a great help.
Old 04-11-2013, 06:09 PM
RhinoScores's Avatar
RhinoScores
RhinoScores is offline
I have to replace the radiaotor in my 2007. I'd love to ee the pics if you can either post or email them. Anyone know of a step by step procedure.
Jrob76
6.4L Power Stroke Diesel
05-04-2017 12:40 PM
0500757Arf
18
03-24-2016 08:19 AM
GreatNorthWoods
21
01-04-2016 01:16 PM
hillcountryflt
09-12-2015 12:29 AM
jtharvey
20
03-14-2008 08:39 AM
Quick Reply: 2007 Explorer radiator install
