i just bought this truck and would like help decoding the vin and data plate. i do not have the info from the data plate yet but the vin is F60BK520244. thank you
ok i got the data plate info. it reads: WB Color Model Body Trans Axle 174 J F602 181 F F8 Max G.V.W LBS Cert Net H.P. RPM D.S.O. 20000 132 3600 452235
sorry that didi not show up how i typed it in. WB 174. Color J. Model F602. Body 181. Trans F. Axle F8. Max G.V.W. LBS 20000. Cert Net H.P. 132. RPM 3600. D.S.O. 452235 hope his one shows up better or that you can at least make sence of it
