Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-25-2003, 11:13 PM
jay70sport is starting off with a positive reputation.
transmission swap
i recently swapped my 3speed for a c4 auto out of a 73 bronco which i have for parts. i have had nothing but headaches!!!! i have pulled it out 3 times for problems. has anyone built one for heavy duty use i.e. severe mud,hill climbing?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-25-2003, 01:57 AM
S1WBuellRider is starting off with a positive reputation.
transmission swap
If I understand you correctly you are having problems with a C4 trans?
If so what kind of problems are you having?
This trans can be built to withstand in excess of 400hp without to much fuss.
I have two Broncos with C4's and wouldnt trade for them. Parts are cheap for them as well.
e-mail me directly if you need help.
Kent
  #3 (permalink)
Old 04-07-2003, 09:52 PM
transmission swap
the c4 shifts and runs fine until it gets hot apprx. 20miles and then trans fluid pours from behind the flywheel. i have replaced the seals and bushings. no luck. it is driving me crazy. any help would be greatly appr.
  #4 (permalink)
Old 04-08-2003, 12:14 AM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
transmission swap
You do have a transmission cooler installed, right? Is it large enough for your Bronco?
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #5 (permalink)
Old 04-10-2003, 10:00 PM
transmission swap
NO I DID NOT INSTALL A COOLER. JUST STRAIGHT TO THE RADIATOR WHICH IS NEW. I DID NOT KNOW IF ONE WAS REQUIRED. DID THE ORIGINAL'S HAVE COOLERS? THE 73 I TOOK IT OUT OF,HAD THE MOTOR AND RADIATOR PULLED OUT OF IT WHEN I BOUGHT IT FOR PARTS. COULD THIS BE MY WHOLE PROBLEM? ANY SUGGESGTIONS FOR AT COOLERS. IT IS KILLING ME HAVING MY BRONCO SITTING IN MY DRIVEWAY WITH THE SPRING WEATHER HERE IN MISS.,AND I HATE TO HAVE A REBUILD UNLESS I NEED IT FOR SURE. THANK YOU FOR ANY HELP.
  #6 (permalink)
Old 04-10-2003, 11:17 PM
RCrawler's Avatar
transmission swap
The cooler is in the radiator itself. As long as it is not plugged, it should be sufficient.
Have you pinpointed the location that it leaks from?
Jason
__________________
  #7 (permalink)
Old 04-12-2003, 10:03 PM
transmission swap
IT IS LEAKING FROM BEHIND THE FLYWHEEL AND POURING STRAIGHT DOWN. I REPLACED THE FRONT SEAL AND BUSHING. STILL THE SAME. IT WILL IDOL ALL DAY LONG AND NOT LEAK,GO DOWN THE ROAD A FEW MILES AND IT BEGINS POURING. AS SOON AS YOU SHUT THE MOTOR OFF IT QUITS. SOMEONE TOLD ME TO CHECK THE VENT TUBE. I THINK I FOUND IT BY HAND,DOES IT HAVE A METAL CAP ON IT? IF SO IT MOVES FREELY UP AND DOWN SO IT DOES NOT APPEAR TO BE STOPPED UP. I AM TRYING TO FIX IT WITHOUT PULLING IT OUT BUT MY OPTIONS ARE RUNNING OUT. THANK YOU FOR ANY HELP. I DOUBLED CHECK MY RADIATOR COOLER TO MAKE SURE IT WASNT STOPPED UP AND IT IS WORKING FINE. THANK YOU FOR ANY HELP
  #8 (permalink)
Old 04-12-2003, 11:36 PM
RCrawler's Avatar
transmission swap
The vent is in the adaptor between the transmission and transfer case.
How does the torque converter look? Was it from your parts truck or did you purchase a new one. It is possible to have a crack in it that will not leak at idle. When you drive it, the transmission fluid pressure builds, causing it to leak. It could also be coming from the front pump itself where it seals to the transmission housing.
Either way, it is going to take pulling the transmission out. You might think about having it built and getting a new converter. To answer your original question, the C4 can be built to handle lots of power and HD use. You just need to focus on what your main use is going to be.
Jason
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
