fuel tank / vent valve - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-30-2010, 11:04 PM
thebirdf thebirdf is offline
thebirdf is starting off with a positive reputation.
hey guys i need some help on 1993 ranger fuel tank ok first i know about the fuel pump but right next to it guess is a vent valve from what i read about for the first time ok here is my question is vent value needs to be connect to a hose? it's my first time removal the fuel tank off ford ranger that ya im ask so if anyone can help me out here would be great thank
Old 10-31-2010, 04:30 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
vent hooks to vacuum hose, sucks the vapor into the engine so that it doesn't escape into the atmosphere and cause smog.
Old 10-31-2010, 09:49 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
If your about to drop the tank to work on, or change the fuel pump, it's said by those that have done it, that it's easier to disconnect the fuel filler hose, tail light wiring harness connector, remove the tailgate to make te bed lighter, then unbolt & slide the bed back to rest the front on the rear tires, the back portion on saw horses.
Then you can access the fuel pump without having to disconnect the fuel fller hose, drain & drop the tank, which is said to be a bigger pia.
Yup as has been said, there is a vacuum line at the tank that goes to the vapor recovery canister & those tank fumes are recovered & used to help the engine start & run easier when cold, so that hose needs to be hooked up & in good condition for the engine to run right, have lower emissions & prevent vapor recovery system trouble codes.
Old 10-31-2010, 01:56 PM
Great thank you for the reply
Old 11-01-2010, 01:43 PM
jhawk7783 jhawk7783 is offline
jhawk7783 is starting off with a positive reputation.
Question about this vapor recovery system: similar no start problem (year 2000 explorer with 4.0 L OHV engine). Replaced fuel pump assembly, fuel filter; have low pressure at fuel rail but engine will run for a few seconds with gas squirted into intake manifold. Voltage at connecter to fuel pump reads 10+ volts. I don't get any DTC codes because battery was disconnected to replace fuel tank. I figured that camshaft posetion and crank postion sensor are OK since engine will run for few seconds.
thanks for any help.
OK to Plug EEC ports on fuel tank? jonmammenga 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-10-2017 01:08 AM
Fuel tank vent vapor valve, two ports? failed smog 1994 Ranger brianm767 Ranger & B-Series 0 02-13-2016 09:30 PM
Fuel tank vent valve question 33homerdoodle 1987 - 1996 F150 & Larger F-Series Trucks 5 01-17-2016 05:00 PM
Fuel tank vent question Matt's Dad Excursion - King of SUVs 0 01-12-2013 04:05 PM
1984 F250 Fuel Tank issue JSP2242 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 11-09-2010 07:40 PM
Tags
1990, 1996, 99, back, f150, ford, fuel, hoses, ranger, replacing, run, tank, truck, valve, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
