1953 Marmon-Herrington M254 manual
You can see the 44 in this picture of a restored .5 ton Studebaker chassis.
http://napco4x4.flux.com/Photo/stude...45000101D58C45
Makes one almost salivate.
the more I learn ..the less I know...more misinformation...well at least I can stop looking at studabakers ...and then I see a 6 bolt wheel and start wondering again...about napco..and parts...one fellow I have talked to here on the island seemed pretty sure he can find most anything I need ..it's amazing what a little phone call can do for your outlook ..new fuel line is in place tomorrow fresh gas and see if the fuel gauge works..
Edit, from admittedly shadowy copies of shadowy photos, I think the first M-1-4 (maybe M-2-4 as well) IHC WW2 4wds used a Timken frontend. If so, I'm almost positive it would have been a full-floater, not a semi-floater like the Timkens used by M-H.
Might all be a mute point if the shaft is a direct replacement for his.
Agree that a 4.86 in a A150 would be a lot more driveable. The stock F-250 rear hubs would be an issue, though, like you said. Looking through the Chassis Manual, the A150 options were 4.86 and 5.83 (not 5.38, sorry). The B150 options were 5.13 and 5.83. Seems MH would logically have geared their products to the lowest gearing option, so are you sure yours is a 4.86? If not, and if Ken's too was geared to the lower optional ratio, it might be a direct bolt in. Stu
Got the manual in the mail yesterday. A LOT of good info. It lists both front axles. The 5 lug Timken 51524 is MH #M254-1475 and the 6 lug Timken A150 axle is #M254-1301. Both have 4.86 gears, the only option listed. The A150 axle must have a wider track because, as I saw on the F-250 MH I parted out, MH installed 5/8" wide spacers on each side of the 5 lug axle to widen the track for the '53 chassis.
I'll be standing at the copier at Staples today for a while. I know that Dave and Ken want copies. If there are other F-250 MH owners out there I'm not thinking of please speak up if you want a copy. Stu
Dirtbag
218
10-04-2019 11:43 PM
51MHF5
17
10-03-2019 06:41 PM
truckdog62563
18
01-22-2018 09:01 PM
truckdog62563
1947 and Older Ford Trucks
02-04-2009 06:26 AM
