knocking noise 97 f150 - Ford Truck Enthusiasts Forums
Old 02-25-2003, 10:05 PM
d.jason d.jason is offline
d.jason is starting off with a positive reputation.
i have a 97 f150 4.2l v6. a coolant leak caused me to run the engine hot but was still drivable after cool down. the coolant leak was from the water pump gasket which was replaced along with the timing cover/oil pump assy. while driving the vehicle home after repairs were complete i noticed a knocking or clattering noise from under the hood as i depressed the clutch to decelerate down the off-ramp. this noise is also evident when accelerating in the upper rpm range especially when pressing the pedal to the metal due to sudden loss of power. i had someone rev it up while i listened under the hood and it sounds like it's from the passenger side head area, maybe a valve. also having trouble with oil pressure.
what do you think
Old 02-25-2003, 10:33 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Welcome to FTE
Noises are very hard to diagnose without actually hearing them.
Overheating an engine can do damage to lots of different parts
What kind of oil pressure problems are you having? Have you checked the oil pressure with a real mechanical gauge? That should probably be your first step in checking it. And you might want to take the truck by a good mechanic and have him listen to it.
I've seen 4.2L engines leak coolant into the oil pan from the front cover and also have seen ones that had the front cover replaced but they didnt change the oil after they were done. Or they had been leaking coolant into the oil for some time. Antifreeze destroys bearings.
I've also seen people use a whole bunch of silicone on the front cover gasket and plug the oil holes. Not good.
Intermittent "engine" knocking underneath_'00_5.4L PEG 1997 - 2003 F150 2 11-18-2015 12:55 PM
Brand new fuel pump makes loud knocking noise - is it "breaking in" or just breaking? Galendor 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 11-05-2015 03:01 PM
Having some Issues with my 2004 f150 5.4l 3v matttrox 2004 - 2008 F150 3 04-20-2015 08:06 PM
'06' knocks when engine is cold only!!! Forwell 2004 - 2008 F150 1 10-17-2014 08:22 PM
6.0 blowing coolant under the hood mlytc 6.0L Power Stroke Diesel 25 09-18-2012 09:21 PM
Tags
2001, 42, 97, antifreeze, engine, f150, knocking, leaking, loss, nocking, noice, noise, power, small, sound, tapping, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
