injector cups - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
injector cups
Old 10-30-2010, 08:35 PM
danman979's Avatar
danman979 danman979 is offline
danman979 is starting off with a positive reputation.
injector cups
Can some one tell me what causes injector cups to crack or leak? I recently took mt 02 F250 7.3 in to have the rad flushed and refilled. It has the gold antifreeze from the factory with 140 thousand KLMs on the odometer. When they were draining the old stuff out they called me in to the shop to show me how much diesel fuel was in the antifreeze. After seeing that they put the old stuff back in and refered me to a local shop that specializes in diesel injectors and turbos. I had no idea what had happened because the level in the degas bottle never changed in 8 years. Now this specialty shop is telling me that I may have 1 or more cracked injector cups that would cause this problem. I was told that it will cost anywhere from $1500.00 to $2000.00 to repair depending on if the cups can be removed with or without removing the heads. I have been using a Diablo Sport tuner for 2 years now on the 85 performance tune for better milage. could this have caused my problems or is some one trying to bleed me from some hard earned money. Please Help
Old 10-30-2010, 09:08 PM
helifixer's Avatar
helifixer helifixer is online now
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
they are thin brass cups. they just crack sometimes. if they think they have to remove the heads find another shop.
Old 10-30-2010, 09:15 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
First you haven't had a cracked cup for 8 years. Second, other than a defective cup or it's installation heat can cause them to crack. If the tuner was causing excess EGTs and you weren't caution that could have caused the cup to crack.
Replacing the cup yourself is the way to go. There is no need to pull the head. The hard part is finding out which cup is cracked. See HERE for some info. Running a CCT and rotaional velocity test may help you narrow it down to one cup.
I replaced all 8 for less then $150.00. Injector Cup R&R. Replacing just one would not be all that difficult. If I had a bad one I would only replace that one. I replaced all mine because I was running ELC in an E99 and was replacing all the injectors as well.
Old 10-30-2010, 09:39 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
As stated earlier. If you are capable of removing some bolts, then you can do this yourself for a few hundred. If not, pay the shop a couple of thousand and hope they don't come at you for more money later.
Drive the truck home, get the cups and removal tool from Clay and just do it yourself.
Old 10-30-2010, 10:07 PM
danman979's Avatar
Thanks for the help guys. First off I dont have the mechanical ability or the facilitys to do such a repair. the shop that is doing the work has a good reputation with some big rig truckers that I know if that helps. With the programmer set at 85 hp I have rarely seen the EGTs go over 1000f . I dont race my truck. When I work it hard Im hauling a 300 gallon water tank or a truck and trailer load of firewood and thats in the 40 hp trailer tow setting. The guys at the repair shop said that I may have waited too long to change the antifreeze and that I should change from the gold stuff to the green and do a flush and fill every 2 years. I drive about 25000 KMs every year all seasons. The truck came with gold but i have read other guys threads where they changed to green with no problems. Any ideas on this?
Old 10-30-2010, 10:12 PM
F350-6's Avatar
Quote:
You can go with whatever color anti-freeze you want as long as you flush your engine good before switching colors. If you go with green, you'll need to buy some test strips and test SCA levels every couple of months to make sure you're withing the allowable tolerance.
Old 10-30-2010, 10:32 PM
danman979's Avatar
thanks for the reply. I live in a small town in Ontario Canada so my choice of repair shops is very limited. I will let the shop do a flush and fill with green antifreeze and get some test strips from the local Napa dealer. I will find out on Monday what the bill is going to be.
Injector Cup R&R PaysonPSD 1999 - 2003 7.3L Power Stroke Diesel 36 12-25-2016 10:42 AM
How bad did I mess this up? bigalsmith102 1994.5 - 1997 7.3L Power Stroke Diesel 35 12-22-2015 09:37 PM
Can the two be linked Degass psi and Leaking Cups spike944t 1999 to 2016 Super Duty 0 12-07-2014 05:35 PM
Anti-freeze odor in crewcab ? jchamb11 1999 - 2003 7.3L Power Stroke Diesel 24 09-30-2011 07:56 AM
Injector cups? parrisw 1994.5 - 1997 7.3L Power Stroke Diesel 8 01-14-2010 08:35 AM
Tags
02, 1999, 2002, cost, cup, cups, diesel, duty, f250, f350, ford, injecor, injector, injuctor, replace, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
